[mpich-discuss] mpich compilation issue
    Anthony Chan
    chan at mcs.anl.gov
    Thu Sep 15 10:30:52 CDT 2011
AFAIK, MPICH1 treats FC as F77.  Your LOG3 still can't configure
Fortran binding.  Here is the relevant lines.  If I were you, I would
spend my effort on fixing the MPI deadlock bug in your code.
A.Chan
+ echo 'configure: warning: Could not find a way to access the command line from Fortran 77'
+ F77_GETARGDECL=
+ F77_IARGC=
+ F77_GETARG=
+ FXX_MODULE=
+ F77_GETARG_FFLAGS=
+ F77_GETARG_LDFLAGS=
+ test -z ''
+ echo 'configure: error: Command line access is required for MPICH'
+ exit 1
+ test 1 '!=' 0
+ echo 'Error configuring the Fortran subsystem!'
+ echo 'Turning off Fortran support'
----- Original Message -----
> Hi,
> please check the config log in detail with options passed as export
> FC=gfortran. It has not created mpif90 nor mpif77. Where things are
> going
> wrong?
> On Wed, Sep 14, 2011 at 10:46 PM, Gus Correa <gus at ldeo.columbia.edu>
> wrote:
> > akshar bhosale wrote:
> > > No, it is not bug because the same code is running in other
> > > machine.
> > Hi Akshar
> > The devilish thing with MPI programs is that success in one machine,
> > or with a certain number of processes, or in a specific network,
> > doesn't mean that the program is bug free.
> > It may still fail in a different environment.
> > [Actually, even sequential programs are like that.
> > In one computer, with a certain compiler, etc,
> > say, a segmentation fault may not appear, may not break
> > at run time, but in another machine/OS/compiler it may.]
> > "It works" is a necessary but not sufficient condition for
> > "being bug-free"
> > The error message you've got is pretty clear.
> > There is a deadlock.
> > See Pavan's suggestion in his email.
> > I hope this helps,
> > Gus Correa
> >>    Can something be done so that even if mpif77 does not get
> >>    created,
> >>    no issues; but mpif90 (mpich-1.2.7p1, gfortran) should get
> >>    created
> >>    and fortran helloworld should run without any issues.
> >> Thank you
> >> Akshar.
> >> On Tue, Sep 13, 2011 at 10:39 PM, Gus Correa
> >> <gus at ldeo.columbia.edu<mailto:
> >> gus at ldeo.columbia.edu>**> wrote:
> >>  Hi Akshar
> >>    It sounds as a bug in the program,
> >>    which causes a deadlock, not a problem with MPICH2.
> >>    Your error message:
> >>     > MPID_Send(57): DEADLOCK: attempting to send a message to the
> >>     > local
> >>     > process without a prior matching receive
> >>    If you post the code, the list may help you.
> >>    Gus Correa
> >>        sorry for not answering why not mpich2.
> >>        We have tried to compile our code using mpich2, it compiles
> >>        but
> >>        while running the executable generated, it runs and in
> >>        between
> >>        it comes out giving some mpi send error. The code compiled
> >>        with
> >>        mpif90 (mpich-1.2.7p1) using gfortran on other machine runs
> >>        fine.
> >>        Error is as follows:
> >>         3 aft MPI_SEND 2 7 2 0
> >>                  3 call MPI_SEND 2 8 2
> >>              0
> >>                  3 aft MPI_SEND 2 8 2
> >>            0
> >>                  3 call MPI_SEND 2 9 2
> >>              0
> >>                  3 aft MPI_SEND 2 9 2
> >>            0
> >>                  3 call MPI_SEND 2 10 2
> >>              0
> >>                  3 aft MPI_SEND 2 10 2
> >>            0
> >>                  3 call MPI_SEND 3 1 3
> >>              0
> >>        [cli_3]: aborting job:
> >>        Fatal error in MPI_Send: Other MPI error, error stack:
> >>        MPI_Send(175): MPI_Send(buf=0x2aaab2af2018, count=1,
> >>        dtype=USER<vector>, dest=3, tag=30003, MPI_COMM_WORLD)
> >>        failed
> >>        local process without a prior matching receive
> >>        -akshar
> >>        On Tue, Sep 13, 2011 at 10:02 PM, akshar bhosale
> >>        <akshar.bhosale at gmail.com
> >>        <mailto:akshar.bhosale at gmail.**com<akshar.bhosale at gmail.com>
> >>        <mailto:akshar.bhosale at gmail._**_com
> >>        <akshar.bhosale at gmail.com>>>>
> >> wrote:
> >>           thanks for reply.
> >>           Goal is to generate mpif90 using mpich-1.2.7p1 using
> >>           gfortran
> >>        which
> >>           will generate executable from our fortran code.
> >>           source files to be compiled are .f and .f90 files.
> >>           f2c flag is given because mp[if90 was not getting
> >>           generated. no
> >>           other reason. we want mpif90.
> >>           Now we have tried giving only FC=gfortran and no other
> >>           flag of
> >>           option except prefix, but still it is not generating
> >>           mpif90
> >>        nor mpif77.
> >>           mpif90 generated by using [export
> >> F90=fortran;F90FLAGS="-ff2c".]
> >>           options if tries to compile our code, it throws error
> >>           <path to mpif90>/mpif90 -f90=gfortran -Wl -o
> >>           ../output_code.x
> >>        set.o
> >>           inp.o otp.o bvsol.o user_kg.o mpi_util.o
> >>           mpi_communication.o
> >>           mpi_memalloc.o driver.o rxn.o advdi_1d_finitediff_mf.o
> >>         aq_lib.o \
> >>                   -L/ioapi/Linux2_x86_64gfort -lioapi
> >>           -L/np_cs/netcdf/INSTALL/lib -lnetcdf -L/usr/lib64/
> >>            -lgomp /np_cs/lapack/lapack-3.2.1/__**lapack_LINUX.a
> >>           /np_cs/lapack/lapack-3.2.1/__**blas_LINUX.a
> >>           /build/lib/libmpich.a(farg.o): In function
> >>           `mpir_iargc__':
> >>           farg.f:(.text+0x6): undefined reference to `f__xargc'
> >>           `mpir_getarg__':
> >>           farg.f:(.text+0x38): undefined reference to `getarg_'
> >>           collect2: ld returned 1 exit status
> >>           make: *** [../output_code.x] Error 1
> >>           -akshar
> >>           On Tue, Sep 13, 2011 at 8:52 PM, Gus Correa
> >>        <gus at ldeo.columbia.edu <mailto:gus at ldeo.columbia.edu>
> >>        <mailto:gus at ldeo.columbia.edu>**>__> wrote:
> >>               Hi Pavan and Akshar
> >>               I see, it's MPICH-1.
> >>               May I ask why?
> >>               Would a workaround perhaps be to build only mpif77
> >>               (no
> >>        mpif90),
> >>               replace 'use mpi' by '#include "mpif.h"' in the
> >>        application code,
> >>               and recompile it with mpif77?
> >>               I wonder if -ff2c works at all with Fortran90.
> >>               (See man page detail below.)
> >>               Anyway, I remember that there were complaints of
> >>               runtime
> >>               errors (P4 errors) with mpich-1,
> >>               reported on this and other mailing lists,
> >>               when running on current Linux kernels.
> >>               Even with simple codes like the cpi example.
> >>               Using MPICH-1 may be an uphill battle.
> >>               I hope this helps,
> >>               Gus Correa
> >>                >From man gfortran (4.1.2):
> >>                     -ff2c
> >>                         Generate code designed to be compatible
> >>                         with code
> >>               generated by g77 and f2c.
> >>                         The calling conventions used by g77
> >>                         (originally
> >>               implemented in f2c) require functions that return
> >>               type
> >>        default
> >>               "REAL" to actually return the C type
> >>                         "double", and functions that return type
> >>        "COMPLEX" to
> >>               return the values via an extra argument in the
> >>               calling
> >>        sequence
> >>               that points to where to store the
> >>                         return value. Under the default GNU calling
> >>               conventions, such functions simply return their
> >>               results
> >>        as they
> >>               would in GNU C -- default "REAL" functions
> >>                         return the C type "float", and "COMPLEX"
> >>                         functions
> >>               return the GNU C type "complex". Additionally, this
> >>               option
> >>               implies the -fsecond-underscore option,
> >>                         unless -fno-second-underscore is explicitly
> >>        requested.
> >>                         This does not affect the generation of code
> >>                         that
> >>               interfaces with the libgfortran library.
> >>                         Caution: It is not a good idea to mix
> >>                         Fortran code
> >>               compiled with "-ff2c" with code compiled with the
> >>               default
> >>               "-fno-f2c" calling conventions as, calling
> >>                         "COMPLEX" or default "REAL" functions
> >>                         between
> >>        program
> >>               parts which were compiled with different calling
> >>               conventions
> >>               will break at execution time.
> >>                         Caution: This will break code which passes
> >>        intrinsic
> >>               functions of type default "REAL" or "COMPLEX" as
> >>               actual
> >>               arguments, as the library implementations
> >>                         use the -fno-f2c calling conventions.
> >>               Pavan Balaji wrote:
> >>                   Gus: He doesn't want to use MPICH2. He's using
> >>                   MPICH-1.
> >>                          -- Pavan
> >>                   On 09/13/2011 09:51 AM, Gus Correa wrote:
> >>                       Hi Akshar
> >>                       Maybe the F90FLAGS="-ff2c" flag is causing
> >>                       the
> >>        problem?
> >>                       What if you remove it and use gfortran for
> >>                       F77
> >>        and FC?
> >>                       Also, my 'configure -help' (a bit old, MPICH2
> >>        1.3.2p1)
> >>                       mentions FC, not F90, as the environment
> >>                       variable
> >>        to be set.
> >>                       For what it is worth, MPICH2 builds fine for
> >>                       us,
> >> with
> >>                       gcc, g++ and gfortran (for F77 and FC).
> >>                       My two cents,
> >>                       Gus Correa
> >>                           Hi,
> >>                              If i specify F77 anf F90 as gfortran,
> >>                              it
> >>        doesn't
> >>                           create mpif90 and
> >>                           mpif77 at all.
> >>                           Please see attached config log
> >>                           If i specify F90=gfortran and
> >>        F90FLAGS="-ff2c", the
> >>                           it creates mpif90
> >>                           and mpif77 but is generating below issue.
> >>                           Kindly help.
> >>                           -akshar
> >>                           On Tue, Sep 13, 2011 at 9:46 AM, Rajeev
> >>                           Thakur<thakur at mcs.anl.gov
> >>        <mailto:thakur at mcs.anl.gov> <mailto:thakur at mcs.anl.gov
> >>        <mailto:thakur at mcs.anl.gov>>
> >>        <mailto:thakur at mcs.anl.gov>>>> wrote:
> >>                               In the configure step, if you specify
> >>        both F77
> >>                           and F90 as gfortran,
> >>                               it should work.
> >>                               Rajeev
> >>                               On Sep 12, 2011, at 9:49 PM, akshar
> >>        bhosale wrote:
> >>                                >  Hi,
> >>                                >  thanks.
> >>                                >  but, in case of mpicc, it can be
> >> ignored,
> >>                           but in case of mpif90,
> >>                               it is still an issue.
> >>                                >  e.g. hello_mpi.f90 program
> >>                                >  program main
> >>                                >     use mpi
> >>                                >  ! implicit none
> >>                                >    integer error
> >>                                >    integer id
> >>                                >    integer p
> >>                                >    real ( kind = 8 ) wtime
> >>                                >  ! Initialize MPI.
> >>                                >    call MPI_Init ( error )
> >>                                >  ! Get the number of processes.
> >>                                >    call MPI_Comm_size (
> >>                                >    MPI_COMM_WORLD,
> >> p,
> >>                           error )
> >>                                >  ! Get the individual process ID.
> >>                                >    call MPI_Comm_rank (
> >>        MPI_COMM_WORLD, id,
> >>                           error )
> >>                                >  ! Print a message.
> >>                                >    if ( id == 0 ) then
> >>                                >      wtime = MPI_Wtime ( )
> >>                                >      write ( *, '(a)' ) ' '
> >>                                >      write ( *, '(a)' ) 'HELLO_MPI
> >>        Master
> >>                           process:'
> >>         FORTRAN90/MPI version'
> >>                                >      write ( *, '(a)' ) ' An MPI
> >>                                >      test
> >>        program.'
> >>                                >      write ( *, '(a,i8)' ) ' The
> >>        number of
> >>                           processes is ', p
> >>                                >    end if
> >>                                >    write ( *, '(a,i8,a)' ) '
> >>                                >    Process
> >>        ', id,
> >>                           ' says "Hello, world!"'
> >>                                >    if ( id == 0 ) then
> >>        Master
> >>                           process:'
> >>                                >      write ( *, '(a)' ) ' Normal
> >>                                >      end of
> >>                           execution: "Goodbye,
> >>                               world!".'
> >>                                >      wtime = MPI_Wtime ( ) - wtime
> >>                                >      write ( *, '(a,g14.6,a)' ) '
> >>  Elapsed
> >>                           wall clock time = ',
> >>                               wtime, ' seconds.'
> >>                                >     end if
> >>                                >   ! Shut down MPI.
> >>                                >    call MPI_Finalize ( error )
> >>                                >    stop
> >>                                >    end
> >>                                >  $ ../../../build/bin/mpif90
> >> hello_mpi.f90
> >>                                   /scratch1/np_cs/trial1/build/_**
> >> ___lib/libmpich.a(farg.o):
> >>                           In function
> >>                               `mpir_iargc__':
> >>        reference to
> >>                           `f__xargc'
> >>                           In function
> >>                               `mpir_getarg__':
> >>        reference to
> >>                           `getarg_'
> >>                                >  status
> >>                                >  On Mon, Sep 12, 2011 at 9:42 AM,
> >>        Rajeev Thakur
> >>        <mailto:thakur at mcs.anl.gov>><_**_mailto:tha__kur at mcs.anl.gov
> >>        <mailto:tha__kur at mcs.anl.gov>
> >>                                >  Ignore that. Compile a real
> >>                                >  program
> >>        as mpicc
> >>                           foo.c.
> >>                                >  On Sep 11, 2011, at 8:38 PM,
> >>                                >  akshar
> >>        bhosale
> >>                           wrote:
> >>                                >  >  Hi,
> >>                                >  >  thank you for reply.
> >>                                >  >  I tried to install it make it
> >>                                >  >  using
> >>                           following options now and i
> >>                               get following error with undefined
> >>        reference to
> >>                           main. options given
> >>                               while configuring the same are :
> >>                                >  >  export
> >>                                >  >  but error of undefined
> >>                                >  >  reference
> >>        to main
> >>                           is observed in every
> >>                               executable like :
> >>                                >  >  ./mpicc -v
> >>                                >  >  mpicc for 1.2.7 (release) of :
> >>        2005/06/22
> >>                           16:33:49
> >>                                >  >  Using built-in specs.
> >>                                >  >  Target: x86_64-redhat-linux
> >>                                >  >  Configured with: ../configure
> >>        --prefix=/usr
> >>                               --mandir=/usr/share/man
> >>                           --infodir=/usr/share/info --enable-shared
> >>                               --enable-threads=posix
> >>        --enable-checking=release
> >>                           --with-system-zlib
> >>                               --enable-__cxa_atexit
> >>        --disable-libunwind-exceptions
> >>                               --enable-libgcj-multifile
> >> --enable-languages=c,c++,objc,**____obj-c++,java,fortran,ada
> >>                               --enable-java-awt=gtk --disable-dssi
> >>                           --disable-plugin
> >> --with-java-home=/usr/lib/jvm/**____java-1.4.2-gcj-1.4.2.0/jre
> >>                               --with-cpu=generic
> >> --host=x86_64-redhat-linux
> >>                                >  >  Thread model: posix
> >>                                >  >  gcc version 4.1.2 20080704
> >>                                >  >  (Red
> >>        Hat 4.1.2-50)
> >> /usr/libexec/gcc/x86_64-____**redhat-linux/4.1.2/collect2
> >>                               --eh-frame-hdr -m elf_x86_64
> >> --hash-style=gnu
> >>                           -dynamic-linker
> >>                               /lib64/ld-linux-x86-64.so.2
> >> /usr/lib/gcc/x86_64-redhat-___**_linux/4.1.2/../../../../**
> >> lib64/____crt1.o
> >> lib64/____crti.o
> >> _linux/4.1.2/crtbegin.o
> >>                               -L/scratch1/np_cs/trial2/____**build/lib
> >>                               -L/opt/intel/mkl/10.2.2.025/__**__lib/em64t<http://10.2.2.025/____lib/em64t>
> >>        <http://10.2.2.025/__lib/em64t**>
> >>                                  <http://10.2.2.025/lib/em64t><**__
> >> http://10.2.2.025/__lib/**em64t <http://10.2.2.025/__lib/em64t>
> >>                           <http://10.2.2.025/lib/em64t>>
> >>                               -L/usr/lib/gcc/x86_64-redhat-_**
> >> ___linux/4.1.2
> >> ___linux/4.1.2
> >> -L/usr/lib/gcc/x86_64-redhat-_**___linux/4.1.2/../../../../**lib64
> >>                               -L/lib/../lib64 -L/usr/lib/../lib64
> >>                               -lmpich
> >>                           -lpthread -lrt -lgcc
> >>                               --as-needed -lgcc_s --no-as-needed
> >>                               -lc -lgcc
> >>                           --as-needed -lgcc_s
> >>                               --no-as-needed
> >> _linux/4.1.2/crtend.o
> >> lib64/____crtn.o
> >> lib64/____crt1.o:
> >>                           In
> >>                               function `_start':
> >>                                >  >  (.text+0x20): undefined
> >>                                >  >  reference
> >>        to `main'
> >>                                >  >  status
> >>                                >  >  ./mpif90 -v
> >>                                >  >  mpif90 for 1.2.7 (release) of
> >>                           2005/06/22 16:33:49
> >>                                >  >  Driving: gfortran
> >>                           -v
> >>                               -lmpichf90 -lmpich -lpthread -lrt
> >>                           -lgfortranbegin -lgfortran -lm
> >>                               -shared-libgcc
> >>        --prefix=/usr
> >>                           --with-system-zlib
> >>                           --disable-plugin
> >>                               --with-cpu=generic
> >>                                >  >  Thread model: posix
> >>                                >  >  (Red
> >>        Hat 4.1.2-50)
> >> --hash-style=gnu
> >>                           -dynamic-linker
> >> lib64/____crt1.o
> >> lib64/____crti.o
> >> ___linux/4.1.2
> >> ___linux/4.1.2
> >>        -lmpichf90
> >>                           -lmpich -lpthread
> >>                               -lrt -lgfortranbegin -lgfortran -lm
> >>                               -lgcc_s
> >>                           -lgcc -lc -lgcc_s -lgcc
> >> lib64/____crtn.o
> >> /usr/lib/gcc/x86_64-redhat-___**_linux/4.1.2/libgfortranbegin.**
> >> ____a(fmain.o):
> >>                               In function `main':
> >>                                >  >  (.text+0xa): undefined
> >>                                >  >  reference
> >>        to `MAIN__'
> >>                                >  >  status
> >>                                >  >  Am i missing somethin?
> >>                                >  >  thank you
> >>                                >  >  -akshar
> >>                                >  >  On Mon, Sep 12, 2011 at 1:24
> >>                                >  >  AM,
> >>        William
> >>                           Gropp
> >>                               <wgropp at illinois.edu
> >>        <mailto:wgropp at illinois.edu>
> >>        <mailto:wgropp at illinois.edu>><**__mailto:wg__ropp at illinois.edu
> >>        <mailto:wg__ropp at illinois.edu>
> >>        <mailto:wgropp at illinois.edu>>>**> wrote:
> >>                                >  >  You can use gfortran for F77
> >>                                >  >  and
> >>        F90. If
> >>                           your requirement is
> >>                               to use gfortran for F77 and a
> >>                               different
> >>        fortran
> >>                           for F90, then they
> >>                               will need to use consistent linker
> >>                               names,
> >>                           calling conventions, data
> >>                               sizes, and libraries. The config.log
> >>        file will
> >>                           have details on why
> >>                               configure decided that the Fortran 77
> >>                               and
> >>                           Fortran 90 compilers were
> >>                               not compatible.
> >>                                >  >  Bill
> >>                                >  >  On Sep 9, 2011, at 4:28 PM,
> >>                                >  >  akshar
> >>                           bhosale wrote:
> >>                                >  >  hi,
> >>                                >  >  we have requirement of
> >>                                >  >  mpich-1.2.7
> >>        with
> >>                           gfortran. We have fiven
> >>                               flags as :
> >>        CC=gcc;F90=fortran;F77=____**gfortran;
> >>                           and tried to configure,
> >>                               it throws error as configure: error:
> >>        Fortran 90
> >>                           and Fortran 77
> >>                               compilers are not compatible..
> >>                                >  >  We have to do it using
> >>                                >  >  gfortran
> >>        only. os
> >>                           is rhel5.1 64 bit
> >>                                >  >  what extran flags settings we
> >>                                >  >  have
> >>        to do?
> >>                                >  >  -akshar
> >>                                   ______________________________**
> >>                                >  >  mpich-discuss mailing list
> >>                     mpich-discuss at mcs.anl.gov
> >>        <mailto:mpich-discuss at mcs.anl.**gov
> >>        <mpich-discuss at mcs.anl.gov>>
> >>                           <mailto:mpich-discuss at mcs.anl.**__gov
> >>        <mpich-discuss at mcs.anl.gov>>>
> >>        <mailto:mpich-discuss at mcs.anl.**>____gov
> >>        <mpich-discuss at mcs.anl.gov>>>>
> >>                                >  >  To manage subscription options
> >>                                >  >  or
> >>                           unsubscribe:
> >>                                   https://lists.mcs.anl.gov/____**
> >> mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss>
> >>        <https://lists.mcs.anl.gov/__**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>
> >>        <https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
> >> **>__>
> >>                                >  >  William Gropp
> >>                                >  >  Director, Parallel Computing
> >> Institute
> >>                                >  >  Deputy Director for Research
> >>                                >  >  Institute for Advanced
> >>                                >  >  Computing
> >>                           Applications and Technologies
> >>                                >  >  Paul and Cynthia Saylor
> >>                                >  >  Professor of
> >>                           Computer Science
> >>                                >  >  University of Illinois
> >>        Urbana-Champaign
> >>                                >  >  or
> >>                           unsubscribe:
> >> **>__>
> >>                                >  To manage subscription options or
> >>        unsubscribe:
> >> **>__>
> >>        unsubscribe:
> >> **>__>
> >>        unsubscribe:
> >> https://lists.mcs.anl.gov/____**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss>
> >> **>__>
> >> ____--------------------------**--__--__------------
> >>         <mailto:mpich-discuss at mcs.anl.**gov<mpich-discuss at mcs.anl.gov>
> >>                           unsubscribe:
> >> **>__>
> >>                       unsubscribe:
> >> **>__>
> >>               ______________________________**_____________________
> >>               mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >>               To manage subscription options or unsubscribe:
> >> **>__>
> >>        ------------------------------**__----------------------------**
> >> --__------------
> >>    <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>
