[mpich-discuss] mpich compilation issue
    Anthony Chan
    chan at mcs.anl.gov
    Tue Sep 13 10:52:06 CDT 2011
> configure: warning: Could not find a way to access the command line from Fortran 77
> configure: error: Command line access is required for MPICH
> Error configuring the Fortran subsystem!
> Turning off Fortran support
The error message in your log indicates that MPICH1 has trouble accessing the command
line feature of the Fortran77.  MPICH2 does not need command line accesses, so it will
be more robust.  BTW, MPICH1 was written before gfortran become popular, so it may not
be trivial to get MPICH1 to work new compiler!  So as Pavan said, you should try using
MPICH2 and post any problems here.
A.Chan
----- Original Message -----
> On 09/13/2011 10:22 AM, Gus Correa wrote:
> > I see, it's MPICH-1.
> > May I ask why?
> Beats me :-).
> Akshar: As already mentioned on the list, MPICH-1 is not supported.
> Please give MPICH2 a try. You didn't quite answer our question on why
> the application doesn't support MPICH2. Did you have some problem
> earlier or are you just following some ancient instructions that say
> "don't use MPICH2 with this application, because when I tried it in
> 1972, it failed"?
> -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
