[mpich-discuss] mpich compilation issue
    akshar bhosale
    akshar.bhosale at gmail.com
    Tue Sep 13 11:32:03 CDT 2011
thanks for reply.
Goal is to generate mpif90 using mpich-1.2.7p1 using gfortran which will
generate executable from our fortran code.
source files to be compiled are .f and .f90 files.
f2c flag is given because mp[if90 was not getting generated. no other
reason. we want mpif90.
Now we have tried giving only FC=gfortran and no other flag of option except
prefix, but still it is not generating mpif90 nor mpif77.
mpif90 generated  by using [export F90=fortran;F90FLAGS="-ff2c".] options if
tries to compile our code, it throws error
<path to mpif90>/mpif90 -f90=gfortran -Wl -o ../output_code.x set.o inp.o
otp.o bvsol.o user_kg.o mpi_util.o mpi_communication.o mpi_memalloc.o
driver.o rxn.o advdi_1d_finitediff_mf.o  aq_lib.o \
        -L/ioapi/Linux2_x86_64gfort -lioapi -L/np_cs/netcdf/INSTALL/lib
-lnetcdf -L/usr/lib64/
 -lgomp /np_cs/lapack/lapack-3.2.1/lapack_LINUX.a
/np_cs/lapack/lapack-3.2.1/blas_LINUX.a
/build/lib/libmpich.a(farg.o): In function `mpir_iargc__':
farg.f:(.text+0x6): undefined reference to `f__xargc'
/build/lib/libmpich.a(farg.o): In function `mpir_getarg__':
farg.f:(.text+0x38): undefined reference to `getarg_'
collect2: ld returned 1 exit status
make: *** [../output_code.x] Error 1
-akshar
On Tue, Sep 13, 2011 at 8:52 PM, Gus Correa <gus at ldeo.columbia.edu> wrote:
> Hi Pavan and Akshar
> I see, it's MPICH-1.
> May I ask why?
> Would a workaround perhaps be to build only mpif77 (no mpif90),
> replace 'use mpi' by '#include "mpif.h"' in the application code,
> and recompile it with mpif77?
> I wonder if -ff2c works at all with Fortran90.
> (See man page detail below.)
> Anyway, I remember that there were complaints of runtime
> errors (P4 errors) with mpich-1,
> reported on this and other mailing lists,
> when running on current Linux kernels.
> Even with simple codes like the cpi example.
> Using MPICH-1 may be an uphill battle.
> I hope this helps,
> Gus Correa
> From man gfortran (4.1.2):
>       -ff2c
>           Generate code designed to be compatible with code generated by
> g77 and f2c.
>           The calling conventions used by g77 (originally implemented in
> f2c) require functions that return type default "REAL" to actually return
> the C type
>           "double", and functions that return type "COMPLEX" to return the
> values via an extra argument in the calling sequence that points to where to
> store the
>           return value.  Under the default GNU calling conventions, such
> functions simply return their results as they would in GNU C -- default
> "REAL" functions
>           return the C type "float", and "COMPLEX" functions return the GNU
> C type "complex".  Additionally, this option implies the -fsecond-underscore
> option,
>           unless -fno-second-underscore is explicitly requested.
>           This does not affect the generation of code that interfaces with
> the libgfortran library.
>           Caution: It is not a good idea to mix Fortran code compiled with
> "-ff2c" with code compiled with the default "-fno-f2c" calling conventions
> as, calling
>           "COMPLEX" or default "REAL" functions between program parts which
> were compiled with different calling conventions will break at execution
> time.
>           Caution: This will break code which passes intrinsic functions of
> type default "REAL" or "COMPLEX" as actual arguments, as the library
> implementations
>           use the -fno-f2c calling conventions.
> Pavan Balaji wrote:
>> Gus: He doesn't want to use MPICH2. He's using MPICH-1.
>>        -- Pavan
>> On 09/13/2011 09:51 AM, Gus Correa wrote:
>>> Hi Akshar
>>> Maybe the F90FLAGS="-ff2c" flag is causing the problem?
>>> What if you remove it and use gfortran for F77 and FC?
>>> Also, my 'configure -help' (a bit old, MPICH2 1.3.2p1)
>>> mentions FC, not F90, as the environment variable to be set.
>>> For what it is worth, MPICH2 builds fine for us, with
>>> gcc, g++ and gfortran (for F77 and FC).
>>> My two cents,
>>> Gus Correa
>>> akshar bhosale wrote:
>>>> Hi,
>>>>    If i specify F77 anf F90 as gfortran, it doesn't create mpif90 and
>>>> mpif77 at all.
>>>> Please see attached config log
>>>> If i specify F90=gfortran and F90FLAGS="-ff2c", the it creates mpif90
>>>> and mpif77 but is generating below issue.
>>>> Kindly help.
>>>> -akshar
>>>> On Tue, Sep 13, 2011 at 9:46 AM, Rajeev Thakur<thakur at mcs.anl.gov
>>>> <mailto:thakur at mcs.anl.gov>>  wrote:
>>>>     In the configure step, if you specify both F77 and F90 as gfortran,
>>>>     it should work.
>>>>     Rajeev
>>>>     On Sep 12, 2011, at 9:49 PM, akshar bhosale wrote:
>>>>      >  Hi,
>>>>      >  thanks.
>>>>      >  but, in case of mpicc, it can be ignored, but in case of mpif90,
>>>>     it is still an issue.
>>>>      >  e.g. hello_mpi.f90 program
>>>>      >  program main
>>>>      >     use mpi
>>>>      >  ! implicit none
>>>>      >    integer error
>>>>      >    integer id
>>>>      >    integer p
>>>>      >    real ( kind = 8 ) wtime
>>>>      >  !  Initialize MPI.
>>>>      >    call MPI_Init ( error )
>>>>      >  !  Get the number of processes.
>>>>      >    call MPI_Comm_size ( MPI_COMM_WORLD, p, error )
>>>>      >  !  Get the individual process ID.
>>>>      >    call MPI_Comm_rank ( MPI_COMM_WORLD, id, error )
>>>>      >  !  Print a message.
>>>>      >    if ( id == 0 ) then
>>>>      >      wtime = MPI_Wtime ( )
>>>>      >      write ( *, '(a)' ) ' '
>>>>      >      write ( *, '(a)' ) 'HELLO_MPI - Master process:'
>>>>      >      write ( *, '(a)' ) '  FORTRAN90/MPI version'
>>>>      >      write ( *, '(a)' ) '  An MPI test program.'
>>>>      >      write ( *, '(a,i8)' ) '  The number of processes is ', p
>>>>      >    end if
>>>>      >    write ( *, '(a,i8,a)' ) '  Process ', id, ' says "Hello,
>>>> world!"'
>>>>      >    if ( id == 0 ) then
>>>>      >      write ( *, '(a)' ) '  Normal end of execution: "Goodbye,
>>>>     world!".'
>>>>      >      wtime = MPI_Wtime ( ) - wtime
>>>>      >      write ( *, '(a,g14.6,a)' ) '  Elapsed wall clock time = ',
>>>>     wtime, ' seconds.'
>>>>      >     end if
>>>>      >   !  Shut down MPI.
>>>>      >    call MPI_Finalize ( error )
>>>>      >    stop
>>>>      >    end
>>>>      >  $ ../../../build/bin/mpif90 hello_mpi.f90
>>>>      >  /scratch1/np_cs/trial1/build/**lib/libmpich.a(farg.o): In
>>>> function
>>>>     `mpir_iargc__':
>>>> function
>>>>     `mpir_getarg__':
>>>>      >  On Mon, Sep 12, 2011 at 9:42 AM, Rajeev Thakur
>>>>     <thakur at mcs.anl.gov<mailto:tha**kur at mcs.anl.gov<thakur at mcs.anl.gov>>>
>>>>  wrote:
>>>>      >  Ignore that. Compile a real program as mpicc foo.c.
>>>>      >  On Sep 11, 2011, at 8:38 PM, akshar bhosale wrote:
>>>>      >  >  Hi,
>>>>      >  >  thank you for reply.
>>>>      >  >  I tried to install it make it using following options now and
>>>> i
>>>>     get following error with undefined reference to main. options given
>>>>     while configuring the same are :
>>>>      >  >  but error of undefined reference to main is observed in every
>>>>     executable like :
>>>>      >  >  ./mpicc -v
>>>>      >  >  mpicc for 1.2.7 (release) of : 2005/06/22 16:33:49
>>>>      >  >  Using built-in specs.
>>>>      >  >  Target: x86_64-redhat-linux
>>>>      >  >  Configured with: ../configure --prefix=/usr
>>>>     --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared
>>>>     --enable-threads=posix --enable-checking=release --with-system-zlib
>>>>     --enable-__cxa_atexit --disable-libunwind-exceptions
>>>>     --enable-libgcj-multifile
>>>>     --enable-languages=c,c++,objc,**obj-c++,java,fortran,ada
>>>>     --enable-java-awt=gtk --disable-dssi --disable-plugin
>>>>     --with-java-home=/usr/lib/jvm/**java-1.4.2-gcj-1.4.2.0/jre
>>>>     --with-cpu=generic --host=x86_64-redhat-linux
>>>>      >  >  Thread model: posix
>>>>      >  >  gcc version 4.1.2 20080704 (Red Hat 4.1.2-50)
>>>>      >  >   /usr/libexec/gcc/x86_64-**redhat-linux/4.1.2/collect2
>>>>     --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker
>>>>     /lib64/ld-linux-x86-64.so.2
>>>>     /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/../../../../lib64/**crt1.o
>>>>     /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/../../../../lib64/**crti.o
>>>>     /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/crtbegin.o
>>>>     -L/scratch1/np_cs/trial2/**build/lib
>>>>     -L/opt/intel/mkl/10.2.2.025/**lib/em64t<http://10.2.2.025/lib/em64t>
>>>> <http://10.2.2.025/**lib/em64t <http://10.2.2.025/lib/em64t>>
>>>>     -L/usr/lib/gcc/x86_64-redhat-**linux/4.1.2
>>>>     -L/usr/lib/gcc/x86_64-redhat-**linux/4.1.2/../../../../lib64
>>>>     -L/lib/../lib64 -L/usr/lib/../lib64 -lmpich -lpthread -lrt -lgcc
>>>>     --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s
>>>>     --no-as-needed /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/crtend.o
>>>>     /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/../../../../lib64/**crtn.o
>>>>     /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/../../../../lib64/**crt1.o:
>>>> In
>>>>     function `_start':
>>>>      >  >  (.text+0x20): undefined reference to `main'
>>>>      >  >  ./mpif90 -v
>>>>      >  >  mpif90 for 1.2.7 (release) of : 2005/06/22 16:33:49
>>>>      >  >  Driving: gfortran -L/scratch1/np_cs/trial2/**build/lib -v
>>>>     -lmpichf90 -lmpich -lpthread -lrt -lgfortranbegin -lgfortran -lm
>>>>     -shared-libgcc
>>>>      >  >  Thread model: posix
>>>>     -L/lib/../lib64 -L/usr/lib/../lib64 -lmpichf90 -lmpich -lpthread
>>>>     -lrt -lgfortranbegin -lgfortran -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc
>>>>     /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/libgfortranbegin.**
>>>> a(fmain.o):
>>>>     In function `main':
>>>>      >  >  (.text+0xa): undefined reference to `MAIN__'
>>>>      >  >  Am i missing somethin?
>>>>      >  >  thank you
>>>>      >  >  -akshar
>>>>      >  >  On Mon, Sep 12, 2011 at 1:24 AM, William Gropp
>>>>     <wgropp at illinois.edu<mailto:wg**ropp at illinois.edu<wgropp at illinois.edu>>>
>>>>  wrote:
>>>>      >  >  You can use gfortran for F77 and F90.  If your requirement is
>>>>     to use gfortran for F77 and a different fortran for F90, then they
>>>>     will need to use consistent linker names, calling conventions, data
>>>>     sizes, and libraries.  The config.log file will have details on why
>>>>     configure decided that the Fortran 77 and Fortran 90 compilers were
>>>>     not compatible.
>>>>      >  >  Bill
>>>>      >  >  On Sep 9, 2011, at 4:28 PM, akshar bhosale wrote:
>>>>      >  >  hi,
>>>>      >  >  we have requirement of mpich-1.2.7 with gfortran. We have
>>>> fiven
>>>>     flags as : CC=gcc;F90=fortran;F77=**gfortran; and tried to
>>>> configure,
>>>>     it throws error as configure: error: Fortran 90 and Fortran 77
>>>>     compilers are not compatible..
>>>>      >  >  We have to do it using gfortran only. os is rhel5.1 64 bit
>>>>      >  >  what extran flags settings we have to do?
>>>>      >  >  -akshar
>>>>      >  >  ______________________________**_________________
>>>>      >  >  mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>>     <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>
>>>>      >  >  To manage subscription options or unsubscribe:
>>>>      >  >  https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
>>>>      >  >  William Gropp
>>>>      >  >  Director, Parallel Computing Institute
>>>>      >  >  Deputy Director for Research
>>>>      >  >  Institute for Advanced Computing Applications and
>>>> Technologies
>>>>      >  >  Paul and Cynthia Saylor Professor of Computer Science
>>>>      >  >  University of Illinois Urbana-Champaign
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110913/20061d9a/attachment-0001.htm>
