[mpich-discuss] mpich compilation issue
    Pavan Balaji
    balaji at mcs.anl.gov
    Tue Sep 13 09:55:28 CDT 2011
Gus: He doesn't want to use MPICH2. He's using MPICH-1.
		-- Pavan
On 09/13/2011 09:51 AM, Gus Correa wrote:
> Hi Akshar
> Maybe the F90FLAGS="-ff2c" flag is causing the problem?
> What if you remove it and use gfortran for F77 and FC?
> Also, my 'configure -help' (a bit old, MPICH2 1.3.2p1)
> mentions FC, not F90, as the environment variable to be set.
> For what it is worth, MPICH2 builds fine for us, with
> gcc, g++ and gfortran (for F77 and FC).
> My two cents,
> Gus Correa
> akshar bhosale wrote:
>> Hi,
>>     If i specify F77 anf F90 as gfortran, it doesn't create mpif90 and
>> mpif77 at all.
>> Please see attached config log
>> If i specify F90=gfortran and F90FLAGS="-ff2c", the it creates mpif90
>> and mpif77 but is generating below issue.
>> Kindly help.
>> -akshar
>> On Tue, Sep 13, 2011 at 9:46 AM, Rajeev Thakur<thakur at mcs.anl.gov
>> <mailto:thakur at mcs.anl.gov>>  wrote:
>>      In the configure step, if you specify both F77 and F90 as gfortran,
>>      it should work.
>>      Rajeev
>>      On Sep 12, 2011, at 9:49 PM, akshar bhosale wrote:
>>       >  Hi,
>>       >  thanks.
>>       >  but, in case of mpicc, it can be ignored, but in case of mpif90,
>>      it is still an issue.
>>       >  e.g. hello_mpi.f90 program
>>       >  program main
>>       >     use mpi
>>       >  ! implicit none
>>       >    integer error
>>       >    integer id
>>       >    integer p
>>       >    real ( kind = 8 ) wtime
>>       >  !  Initialize MPI.
>>       >    call MPI_Init ( error )
>>       >  !  Get the number of processes.
>>       >    call MPI_Comm_size ( MPI_COMM_WORLD, p, error )
>>       >  !  Get the individual process ID.
>>       >    call MPI_Comm_rank ( MPI_COMM_WORLD, id, error )
>>       >  !  Print a message.
>>       >    if ( id == 0 ) then
>>       >      wtime = MPI_Wtime ( )
>>       >      write ( *, '(a)' ) ' '
>>       >      write ( *, '(a)' ) 'HELLO_MPI - Master process:'
>>       >      write ( *, '(a)' ) '  FORTRAN90/MPI version'
>>       >      write ( *, '(a)' ) '  An MPI test program.'
>>       >      write ( *, '(a,i8)' ) '  The number of processes is ', p
>>       >    end if
>>       >    write ( *, '(a,i8,a)' ) '  Process ', id, ' says "Hello, world!"'
>>       >    if ( id == 0 ) then
>>       >      write ( *, '(a)' ) '  Normal end of execution: "Goodbye,
>>      world!".'
>>       >      wtime = MPI_Wtime ( ) - wtime
>>       >      write ( *, '(a,g14.6,a)' ) '  Elapsed wall clock time = ',
>>      wtime, ' seconds.'
>>       >     end if
>>       >   !  Shut down MPI.
>>       >    call MPI_Finalize ( error )
>>       >    stop
>>       >    end
>>       >  $ ../../../build/bin/mpif90 hello_mpi.f90
>>       >  /scratch1/np_cs/trial1/build/lib/libmpich.a(farg.o): In function
>>      `mpir_iargc__':
>>       >  farg.f:(.text+0x6): undefined reference to `f__xargc'
>>      `mpir_getarg__':
>>       >  farg.f:(.text+0x38): undefined reference to `getarg_'
>>       >  collect2: ld returned 1 exit status
>>       >  On Mon, Sep 12, 2011 at 9:42 AM, Rajeev Thakur
>>      <thakur at mcs.anl.gov<mailto:thakur at mcs.anl.gov>>  wrote:
>>       >  Ignore that. Compile a real program as mpicc foo.c.
>>       >  On Sep 11, 2011, at 8:38 PM, akshar bhosale wrote:
>>       >  >  Hi,
>>       >  >  thank you for reply.
>>       >  >  I tried to install it make it using following options now and i
>>      get following error with undefined reference to main. options given
>>      while configuring the same are :
>>       >  >  export F90=fortran;F90FLAGS="-ff2c".
>>       >  >  but error of undefined reference to main is observed in every
>>      executable like :
>>       >  >  ./mpicc -v
>>       >  >  mpicc for 1.2.7 (release) of : 2005/06/22 16:33:49
>>       >  >  Using built-in specs.
>>       >  >  Target: x86_64-redhat-linux
>>       >  >  Configured with: ../configure --prefix=/usr
>>      --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared
>>      --enable-threads=posix --enable-checking=release --with-system-zlib
>>      --enable-__cxa_atexit --disable-libunwind-exceptions
>>      --enable-libgcj-multifile
>>      --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
>>      --enable-java-awt=gtk --disable-dssi --disable-plugin
>>      --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
>>      --with-cpu=generic --host=x86_64-redhat-linux
>>       >  >  Thread model: posix
>>       >  >  gcc version 4.1.2 20080704 (Red Hat 4.1.2-50)
>>       >  >   /usr/libexec/gcc/x86_64-redhat-linux/4.1.2/collect2
>>      --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker
>>      /lib64/ld-linux-x86-64.so.2
>>      /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o
>>      /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
>>      /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbegin.o
>>      -L/scratch1/np_cs/trial2/build/lib
>>      -L/opt/intel/mkl/10.2.2.025/lib/em64t<http://10.2.2.025/lib/em64t>
>>      -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
>>      -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
>>      -L/lib/../lib64 -L/usr/lib/../lib64 -lmpich -lpthread -lrt -lgcc
>>      --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s
>>      --no-as-needed /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtend.o
>>      /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
>>      /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In
>>      function `_start':
>>       >  >  (.text+0x20): undefined reference to `main'
>>       >  >  ./mpif90 -v
>>       >  >  mpif90 for 1.2.7 (release) of : 2005/06/22 16:33:49
>>       >  >  Driving: gfortran -L/scratch1/np_cs/trial2/build/lib -v
>>      -lmpichf90 -lmpich -lpthread -lrt -lgfortranbegin -lgfortran -lm
>>      -shared-libgcc
>>       >  >  Thread model: posix
>>      -L/lib/../lib64 -L/usr/lib/../lib64 -lmpichf90 -lmpich -lpthread
>>      -lrt -lgfortranbegin -lgfortran -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc
>>      /usr/lib/gcc/x86_64-redhat-linux/4.1.2/libgfortranbegin.a(fmain.o):
>>      In function `main':
>>       >  >  (.text+0xa): undefined reference to `MAIN__'
>>       >  >  Am i missing somethin?
>>       >  >  thank you
>>       >  >  -akshar
>>       >  >  On Mon, Sep 12, 2011 at 1:24 AM, William Gropp
>>      <wgropp at illinois.edu<mailto:wgropp at illinois.edu>>  wrote:
>>       >  >  You can use gfortran for F77 and F90.  If your requirement is
>>      to use gfortran for F77 and a different fortran for F90, then they
>>      will need to use consistent linker names, calling conventions, data
>>      sizes, and libraries.  The config.log file will have details on why
>>      configure decided that the Fortran 77 and Fortran 90 compilers were
>>      not compatible.
>>       >  >  Bill
>>       >  >  On Sep 9, 2011, at 4:28 PM, akshar bhosale wrote:
>>       >  >  hi,
>>       >  >  we have requirement of mpich-1.2.7 with gfortran. We have fiven
>>      flags as : CC=gcc;F90=fortran;F77=gfortran; and tried to configure,
>>      it throws error as configure: error: Fortran 90 and Fortran 77
>>      compilers are not compatible..
>>       >  >  We have to do it using gfortran only. os is rhel5.1 64 bit
>>       >  >  what extran flags settings we have to do?
>>       >  >  -akshar
>>       >  >  _______________________________________________
>>       >  >  mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>      <mailto:mpich-discuss at mcs.anl.gov>
>>       >  >  To manage subscription options or unsubscribe:
>>       >  >  https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>       >  >  William Gropp
>>       >  >  Director, Parallel Computing Institute
>>       >  >  Deputy Director for Research
>>       >  >  Institute for Advanced Computing Applications and Technologies
>>       >  >  Paul and Cynthia Saylor Professor of Computer Science
>>       >  >  University of Illinois Urbana-Champaign
Pavan Balaji
http://www.mcs.anl.gov/~balaji
