[mpich-discuss] mpich compilation issue
    Gus Correa
    gus at ldeo.columbia.edu
    Tue Sep 13 09:51:24 CDT 2011
Hi Akshar
Maybe the F90FLAGS="-ff2c" flag is causing the problem?
What if you remove it and use gfortran for F77 and FC?
Also, my 'configure -help' (a bit old, MPICH2 1.3.2p1)
mentions FC, not F90, as the environment variable to be set.
For what it is worth, MPICH2 builds fine for us, with
gcc, g++ and gfortran (for F77 and FC).
My two cents,
Gus Correa
akshar bhosale wrote:
> Hi,
>    If i specify F77 anf F90 as gfortran, it doesn't create mpif90 and
> mpif77 at all.
> Please see attached config log
> If i specify F90=gfortran and F90FLAGS="-ff2c", the it creates mpif90
> and mpif77 but is generating below issue.
> Kindly help.
> -akshar
> On Tue, Sep 13, 2011 at 9:46 AM, Rajeev Thakur <thakur at mcs.anl.gov
> <mailto:thakur at mcs.anl.gov>> wrote:
>     In the configure step, if you specify both F77 and F90 as gfortran,
>     it should work.
>     Rajeev
>     On Sep 12, 2011, at 9:49 PM, akshar bhosale wrote:
>      > Hi,
>      > thanks.
>      > but, in case of mpicc, it can be ignored, but in case of mpif90,
>     it is still an issue.
>      > e.g. hello_mpi.f90 program
>      > program main
>      >    use mpi
>      > ! implicit none
>      >   integer error
>      >   integer id
>      >   integer p
>      >   real ( kind = 8 ) wtime
>      > !  Initialize MPI.
>      >   call MPI_Init ( error )
>      > !  Get the number of processes.
>      >   call MPI_Comm_size ( MPI_COMM_WORLD, p, error )
>      > !  Get the individual process ID.
>      >   call MPI_Comm_rank ( MPI_COMM_WORLD, id, error )
>      > !  Print a message.
>      >   if ( id == 0 ) then
>      >     wtime = MPI_Wtime ( )
>      >     write ( *, '(a)' ) ' '
>      >     write ( *, '(a)' ) 'HELLO_MPI - Master process:'
>      >     write ( *, '(a)' ) '  FORTRAN90/MPI version'
>      >     write ( *, '(a)' ) '  An MPI test program.'
>      >     write ( *, '(a,i8)' ) '  The number of processes is ', p
>      >   end if
>      >   write ( *, '(a,i8,a)' ) '  Process ', id, ' says "Hello, world!"'
>      >   if ( id == 0 ) then
>      >     write ( *, '(a)' ) '  Normal end of execution: "Goodbye,
>     world!".'
>      >     wtime = MPI_Wtime ( ) - wtime
>      >     write ( *, '(a,g14.6,a)' ) '  Elapsed wall clock time = ',
>     wtime, ' seconds.'
>      >    end if
>      >  !  Shut down MPI.
>      >   call MPI_Finalize ( error )
>      >   stop
>      >   end
>      > $ ../../../build/bin/mpif90 hello_mpi.f90
>      > /scratch1/np_cs/trial1/build/lib/libmpich.a(farg.o): In function
>     `mpir_iargc__':
>      > farg.f:(.text+0x6): undefined reference to `f__xargc'
>     `mpir_getarg__':
>      > farg.f:(.text+0x38): undefined reference to `getarg_'
>      > collect2: ld returned 1 exit status
>      > On Mon, Sep 12, 2011 at 9:42 AM, Rajeev Thakur
>     <thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>> wrote:
>      > Ignore that. Compile a real program as mpicc foo.c.
>      > On Sep 11, 2011, at 8:38 PM, akshar bhosale wrote:
>      > > Hi,
>      > > thank you for reply.
>      > > I tried to install it make it using following options now and i
>     get following error with undefined reference to main. options given
>     while configuring the same are :
>      > > export F90=fortran;F90FLAGS="-ff2c".
>      > > but error of undefined reference to main is observed in every
>     executable like :
>      > > ./mpicc -v
>      > > mpicc for 1.2.7 (release) of : 2005/06/22 16:33:49
>      > > Using built-in specs.
>      > > Target: x86_64-redhat-linux
>      > > Configured with: ../configure --prefix=/usr
>     --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared
>     --enable-threads=posix --enable-checking=release --with-system-zlib
>     --enable-__cxa_atexit --disable-libunwind-exceptions
>     --enable-libgcj-multifile
>     --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
>     --enable-java-awt=gtk --disable-dssi --disable-plugin
>     --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
>     --with-cpu=generic --host=x86_64-redhat-linux
>      > > Thread model: posix
>      > > gcc version 4.1.2 20080704 (Red Hat 4.1.2-50)
>      > >  /usr/libexec/gcc/x86_64-redhat-linux/4.1.2/collect2
>     --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker
>     /lib64/ld-linux-x86-64.so.2
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbegin.o
>     -L/scratch1/np_cs/trial2/build/lib
>     -L/opt/intel/mkl/10.2.2.025/lib/em64t <http://10.2.2.025/lib/em64t>
>     -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
>     -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
>     -L/lib/../lib64 -L/usr/lib/../lib64 -lmpich -lpthread -lrt -lgcc
>     --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s
>     --no-as-needed /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtend.o
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In
>     function `_start':
>      > > (.text+0x20): undefined reference to `main'
>      > > ./mpif90 -v
>      > > mpif90 for 1.2.7 (release) of : 2005/06/22 16:33:49
>      > > Driving: gfortran -L/scratch1/np_cs/trial2/build/lib -v
>     -lmpichf90 -lmpich -lpthread -lrt -lgfortranbegin -lgfortran -lm
>     -shared-libgcc
>      > > Thread model: posix
>     -L/lib/../lib64 -L/usr/lib/../lib64 -lmpichf90 -lmpich -lpthread
>     -lrt -lgfortranbegin -lgfortran -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/libgfortranbegin.a(fmain.o):
>     In function `main':
>      > > (.text+0xa): undefined reference to `MAIN__'
>      > > Am i missing somethin?
>      > > thank you
>      > > -akshar
>      > > On Mon, Sep 12, 2011 at 1:24 AM, William Gropp
>     <wgropp at illinois.edu <mailto:wgropp at illinois.edu>> wrote:
>      > > You can use gfortran for F77 and F90.  If your requirement is
>     to use gfortran for F77 and a different fortran for F90, then they
>     will need to use consistent linker names, calling conventions, data
>     sizes, and libraries.  The config.log file will have details on why
>     configure decided that the Fortran 77 and Fortran 90 compilers were
>     not compatible.
>      > > Bill
>      > > On Sep 9, 2011, at 4:28 PM, akshar bhosale wrote:
>      > > hi,
>      > > we have requirement of mpich-1.2.7 with gfortran. We have fiven
>     flags as : CC=gcc;F90=fortran;F77=gfortran; and tried to configure,
>     it throws error as configure: error: Fortran 90 and Fortran 77
>     compilers are not compatible..
>      > > We have to do it using gfortran only. os is rhel5.1 64 bit
>      > > what extran flags settings we have to do?
>      > > -akshar
>      > > _______________________________________________
>      > > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>     <mailto:mpich-discuss at mcs.anl.gov>
>      > > To manage subscription options or unsubscribe:
>      > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>      > > William Gropp
>      > > Director, Parallel Computing Institute
>      > > Deputy Director for Research
>      > > Institute for Advanced Computing Applications and Technologies
>      > > Paul and Cynthia Saylor Professor of Computer Science
>      > > University of Illinois Urbana-Champaign
