[mpich-discuss] LAMMPS execution on Windows 7 no SP1 using MPICH 2.0-1.4.1p1 for windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Sep 13 08:54:02 CDT 2011
>> MPICH2 not installed or unable to query host ...
 This is due to a bug in wmpi* wrapper programs. This does not indicate a faulty installation. Try running "mpiexec -n 2 c:\Progra~1\MPICH2\examples\cpi.exe" and see if it works.
>> Unable to open the ...
 Try running the command from an administrator command prompt (Right-click on command prompt icon and select "Run as administrator".)
 Let us know if it works.
Jayesh
----- Original Message -----
Sent: Monday, September 12, 2011 11:39:58 PM
Subject: [mpich-discuss] LAMMPS execution on Windows 7 no SP1 using MPICH 2.0-1.4.1p1 for windows
I can see smpd running as a service. smpd responds to start and stop commands.
MPICH2 Configurable Settings reports
"spike: MPICH2 not installed or unable to query host"
I used the wmpiregister.exe to associate "behappy" with my mike account. I copied the mpich2mpidll to the winlaamps directory along with the
mpiexec.exe.
I turned off the windows firewall and disabled it. I turned off the Norton firewall and it is disabled as well.
The lmp6.exe is a LAMMPS EXE file copied directly from the LAMMPS site.
C:\winlaamps>mpiexec -np 4 -localonly c:\winlaamps\lmp6 < in.water5
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6240 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\3572 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7056 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7060 registry key, error 5, Access is denied.
I was hoping to get LAMMPS to run quicker (divide and conquer)in a multicore environment.
Thanks in advance for any insight!
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
