[mpich-discuss] Questions about  "Configure"
    Anthony Chan
    chan at mcs.anl.gov
    Fri Sep  9 10:34:26 CDT 2011
I copied and pasted your commmand without looking carefully, you should
be using 1.4.1p1 instead of 1.4.1.
A.Chan
----- Original Message -----
> That is odd! The same test in top-level mpich2 worked but the one
> in src/openpa failed! Both config.guess in src/openpa and top-level
> contain entry to cygwin (openpa's config.guess is newer). Can you redo
> configure as follows:
> > cd /tmp/wadakazusige/mpich2-1.4.1
> > /home/wadakazusige/libraries/mpich2-1.4.1/configure CC=gcc
> > --prefix=/home/wadakazusige/mpich2-install 2>&1 | tee c.txt
> See if it works. If it fails similarly, add "--build=i686-pc-cygwin"
> and see if
> things work.
> A.Chan
> > Dear Sirs and Madams:
> > I am tring to install MPICH2-1.4.1p1 to my stand-alone PC based on
> > Windows
> > XP.
> > While configuring MPICH2, following your "MPICH2 Installer's Guide",
> > I got error message: "OpenPA configure failed", as you can see
> > attached
> > c.txt.
> > I would like to use MPICH2 under Cygwin I already installed.
> > Used commands to configure MPICH2 are as follows:
> > env CC="gcc"
> > 2>&1 | tee c.txt
> > Could you please teach me how to fix this problem.
> > Thank you very much for your support in advance.
> > Best regards,
> > Kazushige Wada
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
