[mpich-discuss] Questions about  "Configure"
    Anthony Chan
    chan at mcs.anl.gov
    Fri Sep  9 10:28:43 CDT 2011
That is odd!  The same test in top-level mpich2 worked but the one
in src/openpa failed!  Both config.guess in src/openpa and top-level
contain entry to cygwin (openpa's config.guess is newer).  Can you redo
configure as follows:
> cd /tmp/wadakazusige/mpich2-1.4.1
> /home/wadakazusige/libraries/mpich2-1.4.1/configure CC=gcc --prefix=/home/wadakazusige/mpich2-install 2>&1 | tee c.txt
See if it works.  If it fails similarly, add "--build=i686-pc-cygwin" and see if
things work.
A.Chan
----- Original Message -----
> Dear Sirs and Madams:
> I am tring to install MPICH2-1.4.1p1 to my stand-alone PC based on
> Windows
> XP.
> While configuring MPICH2, following your "MPICH2 Installer's Guide",
> I got error message: "OpenPA configure failed", as you can see
> attached
> c.txt.
> I would like to use MPICH2 under Cygwin I already installed.
> Used commands to configure MPICH2 are as follows:
> env CC="gcc"
> 2>&1 | tee c.txt
> Could you please teach me how to fix this problem.
> Thank you very much for your support in advance.
> Best regards,
> Kazushige Wada
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
