[mpich-discuss] Hi Darius,
    Darius Buntinas
    buntinas at mcs.anl.gov
    Fri Sep  9 10:22:24 CDT 2011
You need to do a make install.  Once you do that you'll see mpiexec in the bin directory.  Unless you have root access o the machine, you'll need to specify --prefix for the install directory.
-d
On Sep 9, 2011, at 6:54 AM, Rob Stewart wrote:
> Hi,
> On 08/09/11 19:25, Darius Buntinas wrote:
>> You need to pass the -disable-auto-cleanup parameter to mpiexec.
> Thanks for the tip. This parameter isn't available to the mpiexec on my machine - maybe I am missing something.
> In in the mpich2-1.4.1 directory, I've run:
> $ ./configure
> $ make
> Would I expect to find an mpiexec somewhere, e.g. in bin/ ?
> $ find . -name mpiexec
> ./examples/mpiexec
> Or do I need to pass parameters to ./configure to have the mpiexec binary made ?
> Rob Stewart
> Heriot-Watt University is a Scottish charity
> registered under charity number SC000278.
