[mpich-discuss] Compiling with Intel icc
    Thomas Jahns
    jahns at dkrz.de
    Wed Sep  7 12:23:12 CDT 2011
On 09/07/2011 05:03 PM, Dave Goodell wrote:
> On Sep 7, 2011, at 8:48 AM CDT, Thomas Jahns wrote:
>> I also noticed that to make the checks for missing declarations
>> (PAC_FUNC_NEEDS_DECL) work with icc, one needs to add
>> -diag-error 147
>> to MPICH2LIB_CFLAGS.
> We have previously had problems with the PAC_FUNC_NEEDS_DECL macro.  Which
> way is it failing, specifically?
icc only gives a warning where the macro expects compilation to fail. By
escalating the diagnostic for functions called in violation of a declared
interface from warning to error, the configure script correctly identifies these
functions to not need an extra interface.
> Does it cause configure to abort? Does it result in false positives
> (incorrectly determining that a local definition is required) or false
> negatives (incorrectly determining that a local definition is NOT required)?
No abort, but configure gives incorrect results which then result in the
generation of dubious declarations (i.e. substituting int for ssize_t in the
case of readlink, even though sizeof(int) != sizeof(ssize_t)), in your words:
false positives.
> I've never heard of needing "-diag-error 147" with icc, but it's not entirely
> surprising that something is needed.
Might not be required, but at least it reduces warnings during compilation
considerably.
> We put these things on the wiki sometimes, although that can only be modified
> by MPICH2 core developers.  Also the mailing list archives are indexed by
> google and can be a reasonable source of knowledge on these sorts of issues.
> I've added your suggestion to our compiler quirks page:
> http://wiki.mcs.anl.gov/mpich2/index.php/Compiler_Quirks#Intel_Compiler
I see, that documents some compiler properties, but I rather meant setups people
succeeded with, i.e. compiler versions used together and corresponding configure
arguments.
If you are interested: xlf still displays its manual pages in versions 12.x and
13.x and its still just as annoying, or even more so, since the manual pages
only grow longer.
Greetings, Thomas
Thomas Jahns
DKRZ GmbH, Department: Application software
Deutsches Klimarechenzentrum
Bundesstraße 45a
D-20146 Hamburg
Phone: +49-40-460094-151
Fax: +49-40-460094-270
Email: Thomas Jahns <jahns at dkrz.de>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110907/e409e46d/attachment-0001.bin>
