[mpich-discuss] MPICH2 for ARM
    Harald Schuster
    schuster at technikum-wien.at
    Fri Nov 11 03:31:46 CST 2011
Hi
I now tried the cpi example from the mpich2 sources and I also got a
segmentation fault. I used the following configuration:
CFLAGS="-static" CC=arm-linux-gcc ./../configure
--prefix=/mnt/ti_am1707_root/usr/mpich2-install --with-pm=hydra
--disable-f77 --disable-fc --disable-cxx --enable-g=dbg,mem,log
--with-device=ch3:sock --host=arm-linux
How is it possible to trace the execution of the program?!
On 10.11.2011 16:33, Harald Schuster wrote:
> I added the config.log to this mail but i changed the pm from hydra to
> gforker only for testing and know the helloWorld example runs but when
> I tried a example with a broadcast the programm stops without any
> error but it not finishes. The gforker and hydra uses sockets or?
> On 10.11.2011 16:12, Jeff Hammond wrote:
>> I think it will help if you post config.log.
>> Can you run the test that fails within GDB or Valgrind?  I do not
>> think that mpirun itself is segfaulting, but rather that it activates
>> the code path that does.  Maybe this much was clear to you already.
>> Jeff
>> On Thu, Nov 10, 2011 at 3:33 AM, Harald Schuster
>> <schuster at technikum-wien.at>  wrote:
>>> Hi
>>> I use MPICH2 on my normal Linux PC and it works fine. My next goal
>>> is to run
>>> MPICH2 on a arm926 (am1707) which is simulated in SimSoc and where a
>>> normal
>>> linux OS is running. The linux is compiled with the buildroot
>>> 2010.05 and I
>>> use the arm-linux-gcc 4.3.4. I tried to make the the mpich2 with the
>>> arm-linux-gcc and it works. I used the following configuration:
>>> --disable-f77 --disable-fc --disable-cxx --disable-sharedlibs
>>> --host=arm-linux --with-device=ch3:sock
>>> Also the make install process works fine. Then I compiled a small
>>> helloWorld
>>> example with the mpicc for arm and it also works. When I run the
>>> helloWorld
>>> example on the simulated processor I always got an segmentation
>>> fault. For
>>> starting the program I use the following command:
>>> mpirun -np 1 helloWorld
>>> When I start the helloWorld program without the mpirun command I got
>>> the
>>> right output. So I think the segmentation fault is caused by the mpirun
>>> command but I don't know where and what I can do to solve the problem.
>>> Best regards
>>> Harald
>>> _______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111111/7ef9aec1/attachment.htm>
