[mpich-discuss] MPICH2 for ARM
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Nov 11 08:29:21 CST 2011
Perhaps, as previously suggested, with a debugger like GDB?
-Dave
On Nov 11, 2011, at 3:31 AM CST, Harald Schuster wrote:
> Hi
> I now tried the cpi example from the mpich2 sources and I also got a segmentation fault. I used the following configuration:
> CFLAGS="-static" CC=arm-linux-gcc ./../configure --prefix=/mnt/ti_am1707_root/usr/mpich2-install --with-pm=hydra --disable-f77 --disable-fc --disable-cxx --enable-g=dbg,mem,log --with-device=ch3:sock --host=arm-linux
> How is it possible to trace the execution of the program?!
> On 10.11.2011 16:33, Harald Schuster wrote:
>> I added the config.log to this mail but i changed the pm from hydra to gforker only for testing and know the helloWorld example runs but when I tried a example with a broadcast the programm stops without any error but it not finishes. The gforker and hydra uses sockets or?
>> On 10.11.2011 16:12, Jeff Hammond wrote:
>>> I think it will help if you post config.log.
>>> Can you run the test that fails within GDB or Valgrind?  I do not
>>> think that mpirun itself is segfaulting, but rather that it activates
>>> the code path that does.  Maybe this much was clear to you already.
>>> Jeff
>>> On Thu, Nov 10, 2011 at 3:33 AM, Harald Schuster
>>> <schuster at technikum-wien.at>  wrote:
>>>> Hi
>>>> I use MPICH2 on my normal Linux PC and it works fine. My next goal is to run
>>>> MPICH2 on a arm926 (am1707) which is simulated in SimSoc and where a normal
>>>> linux OS is running. The linux is compiled with the buildroot 2010.05 and I
>>>> use the arm-linux-gcc 4.3.4. I tried to make the the mpich2 with the
>>>> arm-linux-gcc and it works. I used the following configuration:
>>>> --disable-f77 --disable-fc --disable-cxx --disable-sharedlibs
>>>> --host=arm-linux --with-device=ch3:sock
>>>> Also the make install process works fine. Then I compiled a small helloWorld
>>>> example with the mpicc for arm and it also works. When I run the helloWorld
>>>> example on the simulated processor I always got an segmentation fault. For
>>>> starting the program I use the following command:
>>>> mpirun -np 1 helloWorld
>>>> When I start the helloWorld program without the mpirun command I got the
>>>> right output. So I think the segmentation fault is caused by the mpirun
>>>> command but I don't know where and what I can do to solve the problem.
>>>> Best regards
>>>> Harald
>>>> _______________________________________________
>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
