[mpich-discuss] MPICH2 for ARM
Jeff Hammond
jhammond at alcf.anl.gov
Thu Nov 10 09:12:33 CST 2011
I think it will help if you post config.log.
Can you run the test that fails within GDB or Valgrind? I do not
think that mpirun itself is segfaulting, but rather that it activates
the code path that does. Maybe this much was clear to you already.
Jeff
On Thu, Nov 10, 2011 at 3:33 AM, Harald Schuster
<schuster at technikum-wien.at> wrote:
> Hi
> I use MPICH2 on my normal Linux PC and it works fine. My next goal is to run
> MPICH2 on a arm926 (am1707) which is simulated in SimSoc and where a normal
> linux OS is running. The linux is compiled with the buildroot 2010.05 and I
> use the arm-linux-gcc 4.3.4. I tried to make the the mpich2 with the
> arm-linux-gcc and it works. I used the following configuration:
> CFLAGS="-static" CC=arm-linux-gcc ./../configure
> --prefix=/mnt/ti_am1707_root/usr/mpich2-install --with-pm=hydra
> --disable-f77 --disable-fc --disable-cxx --disable-sharedlibs
> --host=arm-linux --with-device=ch3:sock
> Also the make install process works fine. Then I compiled a small helloWorld
> example with the mpicc for arm and it also works. When I run the helloWorld
> example on the simulated processor I always got an segmentation fault. For
> starting the program I use the following command:
> mpirun -np 1 helloWorld
> When I start the helloWorld program without the mpirun command I got the
> right output. So I think the segmentation fault is caused by the mpirun
> command but I don't know where and what I can do to solve the problem.
> Best regards
> Harald
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/index.php/User:Jhammond
