[mpich-discuss] NO_Port Error
Pavan Balaji
balaji at mcs.anl.gov
Tue May 31 23:13:18 CDT 2011
Can you upgrade to natty? It uses a newer version of MPICH2, which
doesn't use MPD anymore.
-- Pavan
On 05/31/2011 06:59 PM, Cristina Montañola wrote:
> Hello,
> I experience the same problem as Javad.
> I installed mpich2 in Ubuntu 10.10. Those are the errors I get when
> trying to initialize mpd
> cristina at cristina-laptop:~$ mpd
> mpd_uncaught_except_tb handling:
> <type 'exceptions.IOError'>: [Errno 13] Permission denied:
> '/home/cristina/.mpd.conf'
> /usr/share/mpich2/mpdlib.py 1407 get_parms_from_rcfile
> parmsRCFile = open(parmsRCFilename)
> /usr/bin/mpd 155 run
> self.parmdb.get_parms_from_rcfile(self.parmsToOverride,errIfMissingFile=1)
> /usr/bin/mpd 1647 <module>
> mpd.run()
> cristina at cristina-laptop:~$ mpdboot
> mpdboot_cristina-laptop (handle_mpd_output 420): from mpd on
> cristina-laptop, invalid port info:
> no_port
> The file /home/cristina/.mpd.conf has read and write access only by me
> (700).
> Can anybody provide some help? Thanks in advance.
> Cristina
> WARNING / LEGAL TEXT: This message is intended only for the use of the
> individual or entity to which it is addressed and may contain
> information which is privileged, confidential, proprietary, or exempt
> from disclosure under applicable law. If you are not the intended
> recipient or the person responsible for delivering the message to the
> intended recipient, you are strictly prohibited from disclosing,
> distributing, copying, or in any way using this message. If you have
> received this communication in error, please notify the sender and
> destroy and delete any copies you may have received.
> http://www.bsc.es/disclaimer.htm
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
