[mpich-discuss] NO_Port Error
    Shawn Kim
    shawn.subscribe at gmail.com
    Tue May 31 19:50:56 CDT 2011
Did you set up the password in the file ".mpd.conf"?
For example,
vi .mpd.conf
MPD_SECRETWORD=xxxx (whatever you want)
Also, did you set up the ssh that can access to the other processes
(clients) without password?
- Shawn
On Tue, May 31, 2011 at 6:59 PM, Cristina Montañola <
cristina.montanola at bsc.es> wrote:
>  Hello,
> I experience the same problem as Javad.
> I installed mpich2 in Ubuntu 10.10. Those are the errors I get when trying
> to initialize mpd
> cristina at cristina-laptop:~$ mpd
> mpd_uncaught_except_tb handling:
>   <type 'exceptions.IOError'>: [Errno 13] Permission denied:
> '/home/cristina/.mpd.conf'
>     /usr/share/mpich2/mpdlib.py  1407  get_parms_from_rcfile
>         parmsRCFile = open(parmsRCFilename)
>     /usr/bin/mpd  155  run
> self.parmdb.get_parms_from_rcfile(self.parmsToOverride,errIfMissingFile=1)
>     /usr/bin/mpd  1647  <module>
>         mpd.run()
> cristina at cristina-laptop:~$ mpdboot
> mpdboot_cristina-laptop (handle_mpd_output 420): from mpd on
> cristina-laptop, invalid port info:
> no_port
> The file /home/cristina/.mpd.conf  has read and write access only by me
> (700).
> Can anybody provide some help? Thanks in advance.
> Cristina
> WARNING / LEGAL TEXT: This message is intended only for the use of the
> individual or entity to which it is addressed and may contain information
> which is privileged, confidential, proprietary, or exempt from disclosure
> under applicable law. If you are not the intended recipient or the person
> responsible for delivering the message to the intended recipient, you are
> strictly prohibited from disclosing, distributing, copying, or in any way
> using this message. If you have received this communication in error, please
> notify the sender and destroy and delete any copies you may have received.
> http://www.bsc.es/disclaimer.htm
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110531/d3a73a12/attachment.htm>
