[mpich-discuss] Installation Error
    海上钢琴师
    twq1108 at 163.com
    Tue May 31 20:45:20 CDT 2011
Dear developers,
I want to install mpich2-1.3.2p1 with nemesis using the MX network module. I have installed open-MX on my computer. I used the following configure option:
./configure --prefix=/home/ethgroup/local/mpich2-1.3.2/ --with-pm=mpd --with-device=ch3:nemesis:mx --with-mx=/home/ethgroup/local/open-mx-1.4.0/ --with-mx-lib=/home/ethgroup/local/open-mx-1.4.0/lib64/
but the configure won't succeed any way. It will always stop atromio configure, the error infomation are as followings:
configure: ===== configuring src/mpi/romio =====
configure: executing: /home/ethgroup/software/mpich2-1.3.2p1/src/mpi/romio/configure  '--prefix=/home/ethgroup/local/mpich2-1.3.2/' '--with-pm=mpd' '--with-device=ch3:nemesis:mx' '--with-mx=/home/ethgroup/local/open-mx-1.4.0/' '--with-mx-lib=/home/ethgroup/local/open-mx-1.4.0/lib64/' --disable-option-checking
Configuring with args --prefix=/home/ethgroup/local/mpich2-1.3.2/ --with-pm=mpd --with-device=ch3:nemesis:mx --with-mx=/home/ethgroup/local/open-mx-1.4.0/ --with-mx-lib=/home/ethgroup/local/open-mx-1.4.0/lib64/ --disable-option-checking
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for architecture... LINUX
ROMIO home directory is /home/ethgroup/software/mpich2-1.3.2p1/src/mpi/romio
checking for C compiler default output file name... a.out
checking whether the C compiler works... configure: error: in `/home/ethgroup/software/mpich2-1.3.2p1/src/mpi/romio':
configure: error: cannot run C compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details.
configure: error: src/mpi/romio configure failed
Could you tell me what's wrong here? And what can I do to solve the problem? Thank you very much.
Best wishes.
Yours,
Donald
2011-6-1
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110601/6c3de903/attachment.htm>
