[mpich-discuss] Parallel Quick sort
    Irfan Gul
    hungu.orakzai at gmail.com
    Thu May 19 21:35:28 CDT 2011
>version :MPICH2 1.3.1
>uname -mo
            ia64 GNU/Linux
>Yah dear 100 is the output. which is the size of array I have I entered.
>Yah Friend it is working correctly with out profiling on single and
multiple      processes. and also after profiling when it run on a single
process.
#include <mpi.h>
#include <stdio.h>
#include <stdlib.h>
#define  TRUE 1
#include "math.h"
#include <time.h>
int compare(const void *e1, const void *e2 )
          return (*((int *)e1) - *((int *)e2));
DisplayError(char *str)
    printf("Error: %s \n",str);
int Partition(int *Array,int start,int end)
    int pivo;
    int i, j;
    int tmp;
    pivo=Array[end];
    i=start-1;
    for(j=start;j<end;j++)
        if(Array[j]<=pivo)
            i++;
            tmp=Array[i];
            Array[i]=Array[j];
            Array[j]=tmp;
    tmp=Array[i+1];
    Array[i+1]=Array[end];
    Array[end]=tmp;
    return i+1;
QuickSort(int *Array,int start,int end)
    int r;
    int i;
    if(start<end)
        r=Partition(Array,start,end);
        QuickSort(Array,start,r-1);
        QuickSort(Array,r+1,end);
int PowerOf2(int num)
    int i;
    i=1;
    while(num>0)
        num--;
        i=i*2;
    return i;
PQuickSort(int *Array,int start,int end,int m,int id,int MyRank)
    int i, j;
    int r;
    int LocalLength;
    int *tmp;
    //int newsize;
    MPI_Status status;
    LocalLength=-1;
    double t3,t4,t5;
    if(m==0)
        if(MyRank==id)
        t3=MPI_Wtime();
        qsort(Array, end-start, sizeof(int), compare);
        t4=MPI_Wtime();
        t5=t4-t3;
        printf("Process with ID %d and time %6.3f  \n",MyRank,t5);
        return 0;
    if(MyRank==id)
        LocalLength=end-r;
MPI_Send(&LocalLength,1,MPI_INT,id+PowerOf2(m-1),MyRank,MPI_COMM_WORLD);
        if(LocalLength!=0)
MPI_Send(Array+r+1,LocalLength,MPI_INT,id+PowerOf2(m-1),MyRank,MPI_COMM_WORLD);
    if(MyRank==id+PowerOf2(m-1))
        MPI_Recv(&LocalLength,1,MPI_INT,id,id,MPI_COMM_WORLD,&status);
       if(LocalLength!=0)
            tmp=(int *)malloc(LocalLength*sizeof(int));
            if(tmp==0) DisplayError("Malloc memory error!");
            MPI_Recv(tmp,LocalLength,MPI_INT,id,id,MPI_COMM_WORLD,&status);
    if(id<=MyRank && MyRank<id+PowerOf2(m-1))
        PQuickSort(Array,start,r-1,m-1,id,MyRank);
    if(MyRank>=id+PowerOf2(m-1))
        PQuickSort(tmp,0,LocalLength-1,m-1,id+PowerOf2(m-1),MyRank);
    if((MyRank==id+PowerOf2(m-1)) && (LocalLength!=0))
MPI_Send(tmp,LocalLength,MPI_INT,id,id+PowerOf2(m-1),MPI_COMM_WORLD);
    if((MyRank==id) && (LocalLength!=0))
MPI_Recv(Array+r+1,LocalLength,MPI_INT,id+PowerOf2(m-1),id+PowerOf2(m-1),MPI_COMM_WORLD,&status);
int LogBase2(int num)
    int i, j;
    i=1;
    j=2;
    while(j<num)
        j=j*2;
        i++;
    if(j>num)
        i--;
    return i;
main(int argc,char *argv[])
    int ArraySize;
    int *Array;
    int    MyRank, npes;
    int i, j;
    int m, r;
    double t1,t2,t3;
    MPI_Status status;
    MPI_Init(&argc,&argv);
    MPI_Comm_rank(MPI_COMM_WORLD,&MyRank);
    MPI_Comm_size(MPI_COMM_WORLD,&npes);
    if(MyRank==0)
        ArraySize=1000000;
        printf("%d\n",ArraySize);
        Array=(int *)malloc(ArraySize*sizeof(int));
        if(Array==0)
            printf("Malloc memory error!");
        srand(396);
        for(i=0;i<ArraySize;i++)
            Array[i]=(int)rand()%1000;
            //printf("%10d",Array[i]);
            //    printf("\t");
        printf("\n");
    m=LogBase2(npes);
    MPI_Bcast(&ArraySize,1,MPI_INT,0,MPI_COMM_WORLD);
        t1=MPI_Wtime();
    PQuickSort(Array,0,ArraySize-1,m,0,MyRank);
        t2=MPI_Wtime();
        t3=t2-t1;
    if(MyRank==0)
        //for(i=0;i<ArraySize;i++)
        //    printf("%10d",Array[i]);
        //        printf("\t");
        printf("\n");
    printf("MPI_time :%6.3f\n",t3);
    MPI_Finalize();
    return 0;
> the above code is without profiling and work well
Thanks Friend :)
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110520/6a121ffa/attachment-0001.htm>
