[mpich-discuss] Problem with make during installation of MPICH2
Dylan Parenti geogadmin at geog.ucsb.edu
Tue May 3 11:14:55 CDT 2011
Hi Rajeev,
Attached are the unzipped files.
Thank you!
-Dylan
On 5/3/2011 6:26 AM, Rajeev Thakur wrote:
> Can you send the attachments as regular text files instead of zip?
> Rajeev
> On May 2, 2011, at 9:34 PM, Dylan Parenti wrote:
>> Greetings,
>> We have the following environment (Solaris 10):
>> # uname -a
>> SunOS dantzig 5.10 Generic_141445-09 i86pc i386 i86pc
>> The following step during installation under the root account works with no apparent errors:
>> ./configure --prefix=/opt/mpich2 |&  tee c.txt
>> But fails with errors with:
>> make |&  tee m.txt
>> ...and trying with:
>> make V=1 |&  tee m.txt
>> ...also failed identically to the first try. I even tried using a different shell (sh instead of tcsh, using the appropriate syntax changes), but the same errors at the same point occur.
>> The f77, f90, and gcc all seem to be "noticed" and all are in directories stated in echo $PATH.
>> The m.txt, c.txt, and config.txt files are attached in the zip file.
>> Please advise?
>> Thank you,
>> Dylan
>> Dylan Parenti
>> IT Manager
>> Department of Geography
>> University of California, Santa Barbara
>> 805.308.1247
>> d at geog.ucsb.edu
>> <mpich2-errors.zip>_______________________________________________
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110503/95a792fd/attachment-0002.diff>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110503/95a792fd/attachment-0002.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110503/95a792fd/attachment-0003.diff>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110503/95a792fd/attachment-0003.txt>
