[mpich-discuss] Problem with make during installation of MPICH2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed May  4 15:42:04 CDT 2011
These errors
/var/tmp//ccUgLKs8.s:495: Error: suffix or operands invalid for `mov'
/Var/tmp//ccUgLKs8.s:503: Error: suffix or operands invalid for `mov'
are usually solved by upgrading to a newer version of gcc.
Rajeev
On May 3, 2011, at 11:14 AM, Dylan Parenti wrote:
> Hi Rajeev,
> Attached are the unzipped files.
> Thank you!
> -Dylan
> On 5/3/2011 6:26 AM, Rajeev Thakur wrote:
>> Can you send the attachments as regular text files instead of zip?
>> Rajeev
>> On May 2, 2011, at 9:34 PM, Dylan Parenti wrote:
>>> Greetings,
>>> We have the following environment (Solaris 10):
>>> # uname -a
>>> SunOS dantzig 5.10 Generic_141445-09 i86pc i386 i86pc
>>> The following step during installation under the root account works with no apparent errors:
>>> ./configure --prefix=/opt/mpich2 |&  tee c.txt
>>> But fails with errors with:
>>> make |&  tee m.txt
>>> ...and trying with:
>>> make V=1 |&  tee m.txt
>>> ...also failed identically to the first try. I even tried using a different shell (sh instead of tcsh, using the appropriate syntax changes), but the same errors at the same point occur.
>>> The f77, f90, and gcc all seem to be "noticed" and all are in directories stated in echo $PATH.
>>> The m.txt, c.txt, and config.txt files are attached in the zip file.
>>> Please advise?
>>> Thank you,
>>> Dylan
>>> Dylan Parenti
>>> IT Manager
>>> Department of Geography
>>> University of California, Santa Barbara
>>> 805.308.1247
>>> d at geog.ucsb.edu
>>> <mpich2-errors.zip>_______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> <src-openpa-config.log><c.txt><config.log><m.txt>
