[mpich-discuss] Problem with make during installation of MPICH2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue May  3 08:26:09 CDT 2011
Can you send the attachments as regular text files instead of zip?
Rajeev
On May 2, 2011, at 9:34 PM, Dylan Parenti wrote:
> Greetings,
> We have the following environment (Solaris 10):
> # uname -a
> SunOS dantzig 5.10 Generic_141445-09 i86pc i386 i86pc
> The following step during installation under the root account works with no apparent errors:
> ./configure --prefix=/opt/mpich2 | & tee c.txt
> But fails with errors with:
> make | & tee m.txt
> ...and trying with:
> make V=1 |& tee m.txt
> ...also failed identically to the first try. I even tried using a different shell (sh instead of tcsh, using the appropriate syntax changes), but the same errors at the same point occur.
> The f77, f90, and gcc all seem to be "noticed" and all are in directories stated in echo $PATH.
> The m.txt, c.txt, and config.txt files are attached in the zip file.
> Please advise?
> Thank you,
> Dylan
> Dylan Parenti
> IT Manager
> Department of Geography
> University of California, Santa Barbara
> 805.308.1247
> d at geog.ucsb.edu
> <mpich2-errors.zip>_______________________________________________
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
