[mpich-discuss] mpich2-1.3.2p1 compile error
    Pavan Balaji
    balaji at mcs.anl.gov
    Wed May  4 14:35:02 CDT 2011
FYI, please do not recommend using PLPA to users -- PLPA is deprecated
in 1.4.x and will be removed in a later version.
If hwloc is having a build issue, it needs to be reported to the hwloc
developers.
  -- Pavan
On 05/04/2011 02:33 PM, Anthony Chan wrote:
> The -fvisibility=hidden is just a warning.  The problem seems to be pgcc does
> not like certain construct in topology.c.  I think you could either follow what
> Dave said : Try configuring with the following argument:
> "--without-hydra-bindlib" or possibly "--with-hydra-bindlib=plpa"
> or use another C compiler to compile 1.3.2p1.  If you want to use
> gcc/g++/pgf77/pgf90 to compile mpich2, you probably need something
> newer than mpich2 1.4rc2, see
> http://trac.mcs.anl.gov/projects/mpich2/ticket/1476
> A.Chan
>> Anthony,
>> The config.log attached.
>> Wei Huang
>> huangwei at ucar.edu
>> VETS/CISL
>> National Center for Atmospheric Research
>> P.O. Box 3000 (1850 Table Mesa Dr.)
>> Boulder, CO 80307-3000 USA
>> (303) 497-8924
>> On May 4, 2011, at 11:29 AM, Anthony Chan wrote:
>>> Your configure output shows that hwloc added -fvisibility=hidden to
>>> CFLAGS
>>> and that causes the make failure. Could you send us this file
>>> src/pm/hydra/tools/bind/hwloc/hwloc/config.log
>>> in your build directory ?
>>> A.Chan
>>>> Anthony,
>>>> Probably line:
>>>> PATH: /neem2/huangwei/apps/mpich2-1.4rc2/bin
>>>> caused the confusion, but it is the log file for 1.3.2p1.
>>>> (As I tried 1.4rc2 before and put that line into my path.)
>>>> Attached are two files of the configure and make output
>>>> (saved to files).
>>>> Thanks,
>>>> Wei Huang
>>>> VETS/CISL
>>>> (303) 497-8924
>>>> On May 4, 2011, at 10:43 AM, Anthony Chan wrote:
>>>>> The config.log you sent is from mpich2-1.4rc2 not mpich2-1.3.2p1
>>>>> that you originally reported to have problem. Also pgcc does not
>>>>> seem
>>>>> to have option -fvisibility=hidden which AFAIK is a gcc option...
>>>>> Need your configure and make outputs to find out what's wrong.
>>>>>> config.log which is generated automatically by configure isn't
>>>>>> what
>>>>>> I need yet. We need the configure and make outputs as shown
>>>>>> on your screen, see MPICH2's top-level README file for more
>>>>>> details.
>>>>>>> Attached is the config.log.
>>>>>>> Thanks,
>>>>>>> Wei Huang
>>>>>>> VETS/CISL
>>>>>>> (303) 497-8924
>>>>>>> On May 4, 2011, at 9:40 AM, Anthony Chan wrote:
>>>>>>>> Can you send us the configure and make outputs as stated in the
>>>>>>>> README ?
>>>>>>>> A.Chan
>>>>>>>>> Hi, there,
>>>>>>>>> I tried to compile mpich2-1.3.2p1, and configure with:
>>>>>>>>> setenv CC pgcc
>>>>>>>>> setenv FC pgf90
>>>>>>>>> ./configure \
>>>>>>>>> --prefix=/neem2/huangwei/apps/mpich2-1.3.2p1
>>>>>>>>> When I compile, I go the error message below.
>>>>>>>>> How do I solve this issue?
>>>>>>>>> Thanks,
>>>>>>>>> Wei
>>>>>>>>> VETS/CISL
>>>>>>>>> (303) 497-8924
>>>>>>>>> Making all in src
>>>>>>>>> make[5]: Entering directory
>>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
>>>>>>>>> CC topology.lo
>>>>>>>>> pgcc-Warning-Unknown switch: -fvisibility=hidden
>>>>>>>>> PGC-S-0170-Designated initializers are not supported
>>>>>>>>> (topology.c:
>>>>>>>>> 497)
>>>>>>>>> (topology.c:
>>>>>>>>> 509)
>>>>>>>>> PGC/x86-64 Linux/x86-64 6.2-5: compilation completed with
>>>>>>>>> severe
>>>>>>>>> errors
>>>>>>>>> make[5]: *** [topology.lo] Error 1
>>>>>>>>> make[5]: Leaving directory
>>>>>>>>> make[4]: *** [all-recursive] Error 1
>>>>>>>>> make[4]: Leaving directory
>>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc'
>>>>>>>>> make[3]: *** [all-recursive] Error 1
>>>>>>>>> make[3]: Leaving directory
>>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra'
>>>>>>>>> make[2]: *** [all-redirect] Error 1
>>>>>>>>> make[2]: Leaving directory
>>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm'
>>>>>>>>> make[1]: *** [all-redirect] Error 2
>>>>>>>>> make[1]: Leaving directory
>>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src'
>>>>>>>>> make: *** [all-redirect] Error 2
>>>>>>>>> compiler info:
>>>>>>>>> neem>pgcc -V
>>>>>>>>> pgcc 6.2-5 64-bit target on x86-64 Linux
>>>>>>>>> Copyright 1989-2000, The Portland Group, Inc. All Rights
>>>>>>>>> Reserved.
>>>>>>>>> Copyright 2000-2006, STMicroelectronics, Inc. All Rights
>>>>>>>>> Reserved.
>>>>>>>>> neem>pgf90 -V
>>>>>>>>> pgf90 6.2-5 64-bit target on x86-64 Linux
>>>>>>>>> Reserved.
>>>>>>>>> Reserved.
>>>>>>>>> _______________________________________________
>>>>>>>>> mpich-discuss mailing list
>>>>>>>>> mpich-discuss at mcs.anl.gov
>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
