[mpich-discuss] mpich2-1.3.2p1 compile error
    Anthony Chan
    chan at mcs.anl.gov
    Wed May  4 14:48:18 CDT 2011
Wei,
The offending construct in hwloc's topology.c has been updated in mpich2-1.4rc2.
Could you try 1.4rc2 like the way you configured mpich2-1.3.2p1, i.e. using
pgcc/pgCC/pgf77/pgf90 ?  That way you can avoid PLPA and disabling any
hydra features.
A.Chan
----- Original Message -----
> FYI, please do not recommend using PLPA to users -- PLPA is deprecated
> in 1.4.x and will be removed in a later version.
> If hwloc is having a build issue, it needs to be reported to the hwloc
> developers.
> -- Pavan
> On 05/04/2011 02:33 PM, Anthony Chan wrote:
> > The -fvisibility=hidden is just a warning. The problem seems to be
> > pgcc does
> > not like certain construct in topology.c. I think you could either
> > follow what
> > Dave said : Try configuring with the following argument:
> > "--without-hydra-bindlib" or possibly "--with-hydra-bindlib=plpa"
> > or use another C compiler to compile 1.3.2p1. If you want to use
> > gcc/g++/pgf77/pgf90 to compile mpich2, you probably need something
> > newer than mpich2 1.4rc2, see
> > http://trac.mcs.anl.gov/projects/mpich2/ticket/1476
> > A.Chan
> >> Anthony,
> >> The config.log attached.
> >> Wei Huang
> >> huangwei at ucar.edu
> >> VETS/CISL
> >> National Center for Atmospheric Research
> >> P.O. Box 3000 (1850 Table Mesa Dr.)
> >> Boulder, CO 80307-3000 USA
> >> (303) 497-8924
> >> On May 4, 2011, at 11:29 AM, Anthony Chan wrote:
> >>> Your configure output shows that hwloc added -fvisibility=hidden
> >>> to
> >>> CFLAGS
> >>> and that causes the make failure. Could you send us this file
> >>> src/pm/hydra/tools/bind/hwloc/hwloc/config.log
> >>> in your build directory ?
> >>> A.Chan
> >>>> Anthony,
> >>>> Probably line:
> >>>> PATH: /neem2/huangwei/apps/mpich2-1.4rc2/bin
> >>>> caused the confusion, but it is the log file for 1.3.2p1.
> >>>> (As I tried 1.4rc2 before and put that line into my path.)
> >>>> Attached are two files of the configure and make output
> >>>> (saved to files).
> >>>> Thanks,
> >>>> Wei Huang
> >>>> VETS/CISL
> >>>> (303) 497-8924
> >>>> On May 4, 2011, at 10:43 AM, Anthony Chan wrote:
> >>>>> The config.log you sent is from mpich2-1.4rc2 not mpich2-1.3.2p1
> >>>>> that you originally reported to have problem. Also pgcc does not
> >>>>> seem
> >>>>> to have option -fvisibility=hidden which AFAIK is a gcc
> >>>>> option...
> >>>>> Need your configure and make outputs to find out what's wrong.
> >>>>>> config.log which is generated automatically by configure isn't
> >>>>>> what
> >>>>>> I need yet. We need the configure and make outputs as shown
> >>>>>> on your screen, see MPICH2's top-level README file for more
> >>>>>> details.
> >>>>>>> Attached is the config.log.
> >>>>>>> Thanks,
> >>>>>>> Wei Huang
> >>>>>>> VETS/CISL
> >>>>>>> (303) 497-8924
> >>>>>>> On May 4, 2011, at 9:40 AM, Anthony Chan wrote:
> >>>>>>>> Can you send us the configure and make outputs as stated in
> >>>>>>>> the
> >>>>>>>> README ?
> >>>>>>>> A.Chan
> >>>>>>>>> Hi, there,
> >>>>>>>>> I tried to compile mpich2-1.3.2p1, and configure with:
> >>>>>>>>> setenv CC pgcc
> >>>>>>>>> setenv FC pgf90
> >>>>>>>>> ./configure \
> >>>>>>>>> --prefix=/neem2/huangwei/apps/mpich2-1.3.2p1
> >>>>>>>>> When I compile, I go the error message below.
> >>>>>>>>> How do I solve this issue?
> >>>>>>>>> Thanks,
> >>>>>>>>> Wei
> >>>>>>>>> VETS/CISL
> >>>>>>>>> (303) 497-8924
> >>>>>>>>> Making all in src
> >>>>>>>>> make[5]: Entering directory
> >>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
> >>>>>>>>> CC topology.lo
> >>>>>>>>> pgcc-Warning-Unknown switch: -fvisibility=hidden
> >>>>>>>>> PGC-S-0170-Designated initializers are not supported
> >>>>>>>>> (topology.c:
> >>>>>>>>> 497)
> >>>>>>>>> (topology.c:
> >>>>>>>>> 509)
> >>>>>>>>> PGC/x86-64 Linux/x86-64 6.2-5: compilation completed with
> >>>>>>>>> severe
> >>>>>>>>> errors
> >>>>>>>>> make[5]: *** [topology.lo] Error 1
> >>>>>>>>> make[5]: Leaving directory
> >>>>>>>>> make[4]: *** [all-recursive] Error 1
> >>>>>>>>> make[4]: Leaving directory
> >>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc'
> >>>>>>>>> make[3]: *** [all-recursive] Error 1
> >>>>>>>>> make[3]: Leaving directory
> >>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra'
> >>>>>>>>> make[2]: *** [all-redirect] Error 1
> >>>>>>>>> make[2]: Leaving directory
> >>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm'
> >>>>>>>>> make[1]: *** [all-redirect] Error 2
> >>>>>>>>> make[1]: Leaving directory
> >>>>>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src'
> >>>>>>>>> make: *** [all-redirect] Error 2
> >>>>>>>>> compiler info:
> >>>>>>>>> neem>pgcc -V
> >>>>>>>>> pgcc 6.2-5 64-bit target on x86-64 Linux
> >>>>>>>>> Copyright 1989-2000, The Portland Group, Inc. All Rights
> >>>>>>>>> Reserved.
> >>>>>>>>> Copyright 2000-2006, STMicroelectronics, Inc. All Rights
> >>>>>>>>> Reserved.
> >>>>>>>>> neem>pgf90 -V
> >>>>>>>>> pgf90 6.2-5 64-bit target on x86-64 Linux
> >>>>>>>>> Reserved.
> >>>>>>>>> Reserved.
> >>>>>>>>> _______________________________________________
> >>>>>>>>> mpich-discuss mailing list
> >>>>>>>>> mpich-discuss at mcs.anl.gov
> >>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
