[mpich-discuss] how to enable mpiserial for linux machine
    Anthony Chan
    chan at mcs.anl.gov
    Wed Mar 16 16:08:30 CDT 2011
libmpi-serial.a is likely a serial MPI implementation that is created
by cesm not any typical MPI distributions.
A.Chan
----- Original Message -----
> Dear all,
> I have installed MPICH2 on our linux machine to run our research
> model. It
> was performing normal in parallel mode. However, for a specific
> simulation,
> The model configuration needs to enable the use of MPISERIAL but it
> seems
> the machine does not support it.
> Here is the error while compiling
> "DSEQ_ -DFORTRANUNDERSCORE -DNO_SHR_VMATH -i4 -gopt -Mlist -Mextend
> -byteswapio -Mflushz -Kieee -Ktrap=fp -Mfree
> /home2/meir02/cesm1_0/models/drv/driver/ccsm_driver.F90
> gmake: *** No rule to make target
> `/home2/meir02/cesm1_0/test/test/lib/libmpi-serial.a', needed by
> `/home2/meir02/cesm1_0/test/test/run/ccsm.exe'. Stop."
> I cheched /usr/local/mpi/lib and did not find libmpi-serial.a. Is that
> the
> reason for failed compilation. I wish to get some advice here.
> Thank you very much.
> Rui
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
