[mpich-discuss] Determining latency of MPI communication routines
James Dinan
dinan at mcs.anl.gov
Mon Mar 14 10:39:06 CDT 2011
Hi Vaibhav,
Accurately benchmarking collective operations is tricky. Throughput and
latency are often measured differently, so bandwidth numbers aren't
necessarily convertible into latency numbers. This is because
collective operations issued one after another will overlap with one
another and effectively pipeline. There have been several papers on
this topic that you might find helpful:
http://www.springerlink.com/content/7ygll9u0h02t8mth/
http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.149.3571
Best,
~Jim.
On 3/14/11 9:52 AM, vaibhav dutt wrote:
> Hi all,
> This question might seem out of place but as I was not getting a reply
> from the LLC bench
> discussion group, I though I might get an answer here.
> I am trying to determine latency of MPI communication routines through
> LLC bench tool.
> For MPI_reduce etc. it gives the message size and KB/s in the graph of
> the results.
> For finding the latency of the operation for a given message size I am
> dividing the message size by
> the transfer rate corresponding to that message. Is this the correct way?
> Thank You,
> Vaibhav
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
