[mpich-discuss] APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
Pavan Balaji balaji at mcs.anl.gov
Tue Mar 8 18:33:21 CST 2011
Matthias,
We need to know more about the problem to be able to help. So far we
only know that your application aborts (possibly because your code is
incorrect), and that it hangs if you run it through a debugger.
  -- Pavan
On 03/09/2011 02:34 AM, Matthias Demuzere wrote:
> ha, no, I did use 'gdb' in the runfile:
> mpiexec -n 1 gdb ./ccsm.exe
> On 03/08/2011 10:02 PM, Pavan Balaji wrote:
>> No, you misread my email (it's 'gdb', not '-gdb').
>> % mpiexec -n 1 gdb ./foo
>>     -- Pavan
>> On 03/08/2011 02:37 PM, Matthias Demuzere wrote:
>>> I have tried now to use the -gdb option, but than the execution doesn't halt.
>>> So I have to end it with ctr-x.
>>> Any other ideas?
>>> ________________________________________
>>> This means that your application aborted abnormally. You can try running
>>> your application through a debugger:
>>>      -- Pavan
>>> On 03/08/2011 06:49 AM, Matthias Demuzere wrote:
>>>> All,
>>>> I am trying to run the climate model cesm with mpirun using 1 processor
>>>> (offline single point run). The simulation halts before doing the actual
>>>> simulation and I get the following error:
>>>> Does anyone know what is going wrong?
>>>> Kind regards,
>>>> Matthias
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> mpich-discuss at mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
Pavan Balaji
