[mpich-discuss] APPLICATION TERMINATED WITH THE EXIT STRING: Hangup	(signal 1)
    Matthias Demuzere
    Matthias.demuzere at ees.kuleuven.be
    Wed Mar  9 02:34:45 CST 2011
ha, no, I did use 'gdb' in the runfile:
mpiexec -n 1 gdb ./ccsm.exe
On 03/08/2011 10:02 PM, Pavan Balaji wrote:
> No, you misread my email (it's 'gdb', not '-gdb').
> % mpiexec -n 1 gdb ./foo
>    -- Pavan
> On 03/08/2011 02:37 PM, Matthias Demuzere wrote:
>> I have tried now to use the -gdb option, but than the execution doesn't halt.
>> So I have to end it with ctr-x.
>> Any other ideas?
>> ________________________________________
>> This means that your application aborted abnormally. You can try running
>> your application through a debugger:
>>     -- Pavan
>> On 03/08/2011 06:49 AM, Matthias Demuzere wrote:
>>> All,
>>> I am trying to run the climate model cesm with mpirun using 1 processor
>>> (offline single point run). The simulation halts before doing the actual
>>> simulation and I get the following error:
>>> Does anyone know what is going wrong?
>>> Kind regards,
>>> Matthias
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
FWO Post-doctoral Research Fellow
Department of Earth&  Environmental Sciences
Physical and Regional Geography Research Group
Regional climate studies
Celestijnenlaan 200E
3001 Heverlee (Leuven)
BELGIUM
Tel: + 32 16 326424
Fax: + 32 16 322980
http://geo.kuleuven.be/aow/
www.kuleuven.be/geography
