[mpich-discuss] Crash with hydra on MPI_Finalize
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Mar  7 13:11:18 CST 2011
On Mar 7, 2011, at 1:04 PM CST, Jain, Rohit wrote:
> Yes, seg fault.
> # Attempting stack trace sig 11
> # Signal caught: signo [11]
> It crashes with stacktrace that I showed below. There are no error
> messages. Crash occurs in all the processes.
> I recently started using --enable-debuginfo, as I read instruction
> somewhere (mpich2 docs or totalview) that this option is required to use
> mpich2 with totalview. My intention is to be able to debug my
> application with totalview, not inside mpich2. But, it seem totalview
> requires some visibility inside mpich2 to make some of its feature work.
> And, you are right. mpich2-1.2.1p1 with mpd also crashes in similar way.
> So, any chances of getting it fixed?
Please file a bug report for the issue at http://trac.mcs.anl.gov/projects/mpich2/newticket.
If you have a small test program that we can use to reproduce the problem, that will be helpful and will increase the chances of getting the bug fixed sooner.  Please also note whether it is happening only when you actually are attached with the debugger or if it will also happen without the debugger's involvement.
We'll take a look at it as soon as we reasonably can, but I can't make any promises that it will be fixed very soon.
-Dave
