[mpich-discuss] Crash with hydra on MPI_Finalize
    Jain, Rohit
    Rohit_Jain at mentor.com
    Mon Mar  7 17:40:14 CST 2011
I have filed ticket.
Can you please explain when this option needs to be used?
	--enable-debuginfo      Enable support for debuggers
What features of totalview debugger won't be enabled, if this option is
not used?
Rohit
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Monday, March 07, 2011 11:11 AM
Subject: Re: [mpich-discuss] Crash with hydra on MPI_Finalize
On Mar 7, 2011, at 1:04 PM CST, Jain, Rohit wrote:
> Yes, seg fault.
> # Attempting stack trace sig 11
> # Signal caught: signo [11]
> It crashes with stacktrace that I showed below. There are no error
> messages. Crash occurs in all the processes.
> I recently started using --enable-debuginfo, as I read instruction
> somewhere (mpich2 docs or totalview) that this option is required to
use
> mpich2 with totalview. My intention is to be able to debug my
> application with totalview, not inside mpich2. But, it seem totalview
> requires some visibility inside mpich2 to make some of its feature
work.
> And, you are right. mpich2-1.2.1p1 with mpd also crashes in similar
way.
> So, any chances of getting it fixed?
Please file a bug report for the issue at
http://trac.mcs.anl.gov/projects/mpich2/newticket.
If you have a small test program that we can use to reproduce the
problem, that will be helpful and will increase the chances of getting
the bug fixed sooner.  Please also note whether it is happening only
when you actually are attached with the debugger or if it will also
happen without the debugger's involvement.
We'll take a look at it as soon as we reasonably can, but I can't make
any promises that it will be fixed very soon.
-Dave
mpich-discuss mailing list
