[mpich-discuss] Problem in Installing MPE
    Anthony Chan
    chan at mcs.anl.gov
    Fri Mar  4 13:01:14 CST 2011
This looks like an OpenMPI process manager issue, you may want
to post your question on OpenMPI emailing list.
A.Chan
----- Original Message -----
> Thanks for the help. I am trying to execute NAS benchmark across 2
> Nodes,
> each having 4 cores.
> The execution works fine on a single node, but when I try to execute
> the
> benchmark across 2 Nodes, I
> get an error like:
> mpiexec -machinefile hostfile.txt -n 8 ./ep.A.8
> bash: orted: command not found
> A daemon (pid 22973) died unexpectedly with status 127 while
> attempting
> to launch so we are aborting.
> There may be more information reported by the environment (see above).
> This may be because the daemon was unable to find all the needed
> shared
> libraries on the remote node. You may set your LD_LIBRARY_PATH to have
> the
> location of the shared libraries on the remote nodes and this will
> automatically be forwarded to the remote nodes.
> mpiexec noticed that the job aborted, but has no info as to the
> process
> that caused that situation.
> mpiexec: clean termination accomplished
> Can anybody please suggest the reason for this.
> Thanks,
> Vaibhav
> On Thu, Mar 3, 2011 at 8:19 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > You should do configure and make as regular user,
> > and install as root if the install directory is a root
> > writeable only, e.g. /usr/local. But if you install MPE
> > to your home directory or somewhere you as a regular user
> > has write permission, you can do everything as a regular user.
> > A.Chan
> > > Hi,
> > > I am trying to install MPE and I am facing a problem.
> > > The ./configure and make operations work fine but when
> > > I am executing make install, it gives me error as:
> > > /usr/bin/install: cannot create regular file
> > > `/usr/local/include/clog_commset.h': Permission denied
> > > So I become root user and then try to execute make install, but
> > > then I
> > > get
> > > an error like:
> > > /bin/sh: ./sbin/mpeinstall: Permission denied
> > > make: *** [install] Error 126
> > > Can anybody please suggest the reason of the above.
> > > Thank You,
> > > Vaibhav
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
