[mpich-discuss] Problem in Installing MPE
vaibhav dutt
vaibhavsupersaiyan9 at gmail.com
Fri Mar 4 12:55:28 CST 2011
Thanks for the help. I am trying to execute NAS benchmark across 2 Nodes,
each having 4 cores.
The execution works fine on a single node, but when I try to execute the
benchmark across 2 Nodes, I
get an error like:
mpiexec -machinefile hostfile.txt -n 8 ./ep.A.8
bash: orted: command not found
A daemon (pid 22973) died unexpectedly with status 127 while attempting
to launch so we are aborting.
There may be more information reported by the environment (see above).
This may be because the daemon was unable to find all the needed shared
libraries on the remote node. You may set your LD_LIBRARY_PATH to have the
location of the shared libraries on the remote nodes and this will
automatically be forwarded to the remote nodes.
mpiexec noticed that the job aborted, but has no info as to the process
that caused that situation.
mpiexec: clean termination accomplished
Can anybody please suggest the reason for this.
Vaibhav
On Thu, Mar 3, 2011 at 8:19 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> You should do configure and make as regular user,
> and install as root if the install directory is a root
> writeable only, e.g. /usr/local. But if you install MPE
> to your home directory or somewhere you as a regular user
> has write permission, you can do everything as a regular user.
> A.Chan
> > Hi,
> > I am trying to install MPE and I am facing a problem.
> > The ./configure and make operations work fine but when
> > I am executing make install, it gives me error as:
> > /usr/bin/install: cannot create regular file
> > `/usr/local/include/clog_commset.h': Permission denied
> > So I become root user and then try to execute make install, but then I
> > get
> > an error like:
> > /bin/sh: ./sbin/mpeinstall: Permission denied
> > make: *** [install] Error 126
> > Can anybody please suggest the reason of the above.
> > Thank You,
> > Vaibhav
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110304/2d68b0cc/attachment.htm>
