[mpich-discuss] installing and using MPI_PUBLISH_NAME and	MPI_LOOKUP_NAME with mpich2
    Bernard Secher - SFME/LGLS
    bernard.secher at cea.fr
    Thu Jun 16 04:12:43 CDT 2011
When I tried to use hydra_nameserver I get the followinf error message
when I launch my application:
[secher at is209011 essai]$ [mpiexec at is209011] HYDU_sock_read
(/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/utils/sock/sock.c:223):
read errno (Input/output error)
[mpiexec at is209011] control_cb
(/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:249):
assert (!closed) failed
[mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
(/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/tools/demux/demux_poll.c:77):
callback returned error status
[mpiexec at is209011] HYD_pmci_wait_for_completion
(/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:206):
error waiting for event
[mpiexec at is209011] main
(/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/ui/mpich/mpiexec.c:404):
process manager error waiting for completion
What is wrong
My application is just a little test program. I have attached it to this
message.
Bernard
Pavan Balaji a écrit :
> [please keep mpich-discuss cc'ed]
> On 06/16/2011 02:18 AM, Bernard Secher - SFME/LGLS wrote:
>> How can I use the default publish mechanism? My Publish/lookup is
>> hapenning between two different applications. Is there an option to give
>> to mpiexec for that ?
> Do you have a shared file-system? If yes, you don't need to modify
> anything. It should just work. If no, then read below:
>> If I use the pmi option, the mpiexec -nameserver -help give the
>> following message:
>> -nameserver: Nameserver to use for publish/lookup (format is host:port)
>> I don't understand what I have to do with this option.
>> First I launch the hydra_nameserver . Do I give some options to
>> hydra_nameserver ? Do I give some options then, to the two mpiexec to
>> launch my two applications?
> There are no options required for hydra_nameserver. The two mpiexec's
> will need the -nameserver {hostname} option, where {hostname} is the
> name of the host where the nameserver is running.
>  -- Pavan
       _\\|//_
      (' 0 0 ')
____ooO  (_) Ooo______________________________________________________
 Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto : bsecher at cea.fr
 CEA Saclay, Bât 454, Pièce 114        Phone  : 33 (0)1 69 08 73 78
 91191 Gif-sur-Yvette Cedex, France    Fax    : 33 (0)1 69 08 10 87
------------Oooo---------------------------------------------------
       oooO (   )
        \ ( (_/
         \_)
Ce message électronique et tous les fichiers attachés qu'il contient
sont confidentiels et destinés exclusivement à l'usage de la personne
à laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
merci d'en avertir immédiatement son émetteur et de ne pas en conserver
de copie.
This e-mail and any files transmitted with it are confidential and
intended solely for the use of the individual to whom they are addressed.
If you have received this e-mail in error please inform the sender
immediately, without keeping any copy thereof.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/320cd320/attachment.htm>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/320cd320/attachment.cxx>
