[mpich-discuss] installing and using MPI_PUBLISH_NAME and	MPI_LOOKUP_NAME with mpich2
    Pavan Balaji
    balaji at mcs.anl.gov
    Thu Jun 16 10:29:24 CDT 2011
Hi Bernard,
You didn't answer my first question. Can you please let us know about this:
 >> Do you have a shared file-system? If yes, you don't need to modify
 >> anything. It should just work. If no, then read below:
With respect to the test program, what's the exact usage? It looks like
it needs to be run with more than 1 process. You mentioned that there
are two applications? Are both using the same executable (with different
input arguments)?
  -- Pavan
On 06/16/2011 04:12 AM, Bernard Secher - SFME/LGLS wrote:
> When I tried to use hydra_nameserver I get the followinf error message
> when I launch my application:
> [secher at is209011 essai]$ [mpiexec at is209011] HYDU_sock_read
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/utils/sock/sock.c:223):
> read errno (Input/output error)
> [mpiexec at is209011] control_cb
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:249):
> assert (!closed) failed
> [mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/tools/demux/demux_poll.c:77):
> callback returned error status
> [mpiexec at is209011] HYD_pmci_wait_for_completion
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:206):
> error waiting for event
> [mpiexec at is209011] main
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/ui/mpich/mpiexec.c:404):
> process manager error waiting for completion
> What is wrong
> My application is just a little test program. I have attached it to this
> message.
> Bernard
> Pavan Balaji a écrit :
>> [please keep mpich-discuss cc'ed]
>> On 06/16/2011 02:18 AM, Bernard Secher - SFME/LGLS wrote:
>>> How can I use the default publish mechanism? My Publish/lookup is
>>> hapenning between two different applications. Is there an option to give
>>> to mpiexec for that ?
>>> If I use the pmi option, the mpiexec -nameserver -help give the
>>> following message:
>>> -nameserver: Nameserver to use for publish/lookup (format is host:port)
>>> I don't understand what I have to do with this option.
>>> First I launch the hydra_nameserver . Do I give some options to
>>> hydra_nameserver ? Do I give some options then, to the two mpiexec to
>>> launch my two applications?
>> There are no options required for hydra_nameserver. The two mpiexec's
>> will need the -nameserver {hostname} option, where {hostname} is the
>> name of the host where the nameserver is running.
>> -- Pavan
>         _\\|//_
>        (' 0 0 ')
> ____ooO  (_) Ooo______________________________________________________
>   Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto :bsecher at cea.fr
>   CEA Saclay, Bât 454, Pièce 114        Phone  : 33 (0)1 69 08 73 78
>   91191 Gif-sur-Yvette Cedex, France    Fax    : 33 (0)1 69 08 10 87
> ------------Oooo---------------------------------------------------
>         oooO (   )
>          \ ( (_/
>           \_)
> Ce messageélectronique et tous les fichiers attachés qu'il contient
> sont confidentiels et destinés exclusivementà  l'usage de la personne
> à  laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
> merci d'en avertir immédiatement sonémetteur et de ne pas en conserver
> de copie.
> This e-mail and any files transmitted with it are confidential and
> intended solely for the use of the individual to whom they are addressed.
> If you have received this e-mail in error please inform the sender
> immediately, without keeping any copy thereof.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
