[mpich-discuss] [mpich2-announce] Announcing the availability of mpich2-1.3rc1
Pavan Balaji
balaji at mcs.anl.gov
Wed Sep 22 11:03:34 CDT 2010
Joe,
MPICH2 svn now requires svn version >= 1.6. It looks like your svn version is lower than that?
-- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
----- "Joe Ratterman" <jratt0 at gmail.com> wrote:
> I'm trying to clone the new svn tag, but I'm getting an svn error:
> svn: URL '
> https://svn.mcs.anl.gov/repos/mpi/mpich2/tags/release/mpich2-1.3rc1/maint/Version
> ' refers to a file, not a directory
> After this, svn exits with a non-zero return code. You can see the
> behavior with this script. "Done" will not be printed.
> #!/bin/sh -xe
> svn co
> echo Done
> Why is this happening? Should I just ignore it?
> Thanks,
> Joe Ratterman
> jratt at us.ibm.com
> On Wed, Sep 22, 2010 at 4:15 AM, Pavan Balaji < balaji at mcs.anl.gov >
> wrote:
> A release candidate for the new version of MPICH2 (1.3rc1) is
> available from
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> MPICH2-1.3 is a new major-feature addition release intended for stable
> production platforms. This release candidate is meant for early trials
> of this release. Other major additions are highlighted below. Please
> try it out and let us know if you encounter any problems at
> mpich-discuss at mcs.anl.gov .
> Windows binaries will available from the downloads page soon.
> Regards,
> The MPICH2 Team
> Changes in 1.3
> # OVERALL: Initial support for fine-grained threading in
> ch3:nemesis:tcp.
> # OVERALL: Support for Asynchronous Communication Progress.
> # OVERALL: The ssm and shm channels have been removed.
> # OVERALL: Checkpoint/restart support using BLCR.
> # OVERALL: Experimental support for inter-library dependencies.
> # PM/PMI: Hydra is now the default process management framework
> replacing MPD.
> # PM/PMI: Added dynamic process support for Hydra.
> # PM/PMI: Added support for LSF, SGE and POE in Hydra.
> # PM/PMI: Added support for CPU and memory/cache topology aware
> process-core binding.
> # DEBUGGER: Improved support and bug fixes in the Totalview support.
> # Build system: Replaced F90/F90FLAGS by FC/FCFLAGS. F90/F90FLAGS are
> not longer supported in the configure.
> # Multi-compiler support: On systems where C compiler that is used to
> build mpich2 libraries supports multiple weak symbols and multiple
> aliases,
> the Fortran binding built in the mpich2 libraries can handle different
> Fortran compilers (than the one used to build mpich2). Details in
> README.
> # Several other minor bug fixes, memory leak fixes, and code cleanup.
> A full list of changes is available using:
> svn log -r5762:HEAD
> ... or at the following link:
> https://trac.mcs.anl.gov/projects/mpich2/log/mpich2/tags/release/mpich2-1.3rc1?action=follow_copy&rev=HEAD&stop_rev=5762&mode=follow_copy
> Pavan Balaji
> mpich-discuss mailing list
