[mpich-discuss] [mpich2-announce] Announcing the availability	of mpich2-1.3rc1
    Joe Ratterman
    jratt0 at gmail.com
    Wed Sep 22 13:40:03 CDT 2010
Ok, I'll try to get that upgraded.
Thanks.
On Wed, Sep 22, 2010 at 11:03 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Joe,
> MPICH2 svn now requires svn version >= 1.6. It looks like your svn version
> is lower than that?
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
> ----- "Joe Ratterman" <jratt0 at gmail.com> wrote:
> > I'm trying to clone the new svn tag, but I'm getting an svn error:
> > svn: URL '
> https://svn.mcs.anl.gov/repos/mpi/mpich2/tags/release/mpich2-1.3rc1/maint/Version
> > ' refers to a file, not a directory
> > After this, svn exits with a non-zero return code. You can see the
> > behavior with this script. "Done" will not be printed.
> > #!/bin/sh -xe
> > svn co
> > echo Done
> > Why is this happening? Should I just ignore it?
> > Thanks,
> > Joe Ratterman
> > jratt at us.ibm.com
> > On Wed, Sep 22, 2010 at 4:15 AM, Pavan Balaji < balaji at mcs.anl.gov >
> > wrote:
> > A release candidate for the new version of MPICH2 (1.3rc1) is
> > available from
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> > MPICH2-1.3 is a new major-feature addition release intended for stable
> > production platforms. This release candidate is meant for early trials
> > of this release. Other major additions are highlighted below. Please
> > try it out and let us know if you encounter any problems at
> > mpich-discuss at mcs.anl.gov .
> > Windows binaries will available from the downloads page soon.
> > Regards,
> > The MPICH2 Team
> > Changes in 1.3
> > # OVERALL: Initial support for fine-grained threading in
> > ch3:nemesis:tcp.
> > # OVERALL: Support for Asynchronous Communication Progress.
> > # OVERALL: The ssm and shm channels have been removed.
> > # OVERALL: Checkpoint/restart support using BLCR.
> > # OVERALL: Experimental support for inter-library dependencies.
> > # PM/PMI: Hydra is now the default process management framework
> > replacing MPD.
> > # PM/PMI: Added dynamic process support for Hydra.
> > # PM/PMI: Added support for LSF, SGE and POE in Hydra.
> > # PM/PMI: Added support for CPU and memory/cache topology aware
> > process-core binding.
> > # DEBUGGER: Improved support and bug fixes in the Totalview support.
> > # Build system: Replaced F90/F90FLAGS by FC/FCFLAGS. F90/F90FLAGS are
> > not longer supported in the configure.
> > # Multi-compiler support: On systems where C compiler that is used to
> > build mpich2 libraries supports multiple weak symbols and multiple
> > aliases,
> > the Fortran binding built in the mpich2 libraries can handle different
> > Fortran compilers (than the one used to build mpich2). Details in
> > README.
> > # Several other minor bug fixes, memory leak fixes, and code cleanup.
> > A full list of changes is available using:
> > svn log -r5762:HEAD
> > ... or at the following link:
> https://trac.mcs.anl.gov/projects/mpich2/log/mpich2/tags/release/mpich2-1.3rc1?action=follow_copy&rev=HEAD&stop_rev=5762&mode=follow_copy
> > Pavan Balaji
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100922/830cee3b/attachment.htm>
