[mpich-discuss] openSCManger fails in Windows 7 Home Premium
John Joseph
John.Joseph at utsa.edu
Fri Nov 19 23:56:25 CST 2010
Hello.
I'm trying to use MPICH2 to install and run the R package Rmpi on a Windows 7 Home Premium (64-bit) OS, on an Intel Core i7 desktop computer.
I use R on this computer with no problem. It's 32-bit, and installed in C:\Program Files (x86).
I followed instructions posted at http://www.stats.uwo.ca/faculty/yu/Rmpi/windows.htm. In particular, I did the following:
1.) I downloaded the 32-bit version of MPICH2 1.3, and followed the installation wizard prompts.
2) In the "Advanced System Settings" I edited the variable PATH value by adding ";C:\Program Files (x86)\MPICH2\bin" to the value.
3) I launched wmpiconfig.exe from the Start menu, gave my administrator account name and password, clicked "Register" then "OK". When the Configurable Settings dialog box appeared I clicked "Get Settings". At this point I should get a green color on the left hosts panel, but I don't, so I am then supposed to (according to the above website instructions) type at the command prompt while logged on as the administrator the following: smpd -install -phrase behappy. ("behappy" is simply a passphrase). But I get this message:
OpenSCManager failed:
"Access is denied. <error 5>
Unable to remove the previous installation, install failed.
The part "Unable to remove the previous installation" makes me suspect that a previous attempt I had made a mistake on had left some files that needed to be removed before I could try again. So, I did a "system restore" to a point before I had ever tried to install MPICH2. Then I repeated the above steps. But I still got exactly the same message.
I've read a posting for another person who had credential problems with Windows 7 Pro Edition, rather than Windows 7 Home Premium, but I couldn't see how I could apply it to my case. Also, chapter 9 of the Installation Guide doesn't cover this situation directly, as far as I can tell.
Any ideas would be much appreciated.
John Joseph
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101119/8b5bcc13/attachment.htm>
