[mpich-discuss] working mpi, now launch failure
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Nov 19 15:13:49 CST 2010
That is strange.
Please follow the steps below to provide us with the verbose/debug output from mpiexec and smpd.
# Right-click on the command prompt icon and select "Run as administrator". This opens an admin command promt, use this prompt for the steps below.
# Stop any instances of the process manager, smpd, running in your system by using the "-stop" option of smpd (Type "smpd -stop" at command prompt)
# Start smpd in debug mode and redirect output to a file (Type "smpd -d > smpd.log" at the command prompt)
# Open another admin command prompt as mentioned above
# Run mpiexec in verbose mode to launch hostname.exe and redirect the output to a file (Type "mpiexec -verbose -n 2 hostname > mpiexec.log" at the command prompt)
# Ctrl-C in the window where smpd was launched in the debug mode & start smpd in normal mode using the "-start" option (Type "smpd -start" at the command prompt)
Provide us with the smpd and mpiexec logs, smpd.log and mpiexec.log .
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Fri, 19 Nov 2010 14:41:58 -0600 (CST)
Subject: RE: [mpich-discuss] working mpi, now launch failure
Jayesh,
Here is the copy and pasted commands and outputs based on your suggestions:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Administrator>cd ..\Emil\Documents\LAAMPS
C:\Users\Emil\Documents\LAAMPS>mpiexec -n 2 hostname
launch failed: FAIL
launch failed: FAIL
C:\Users\Emil\Documents\LAAMPS>mpiexec -remove
Account and password removed from the Registry.
C:\Users\Emil\Documents\LAAMPS>mpiexec -register
account (domain\user) [ETL5\Administrator]:
password:
confirm password:
Password encrypted into the Registry.
C:\Users\Emil\Documents\LAAMPS>mpiexec -validate
SUCCESS
launch failed: FAIL
launch failed: FAIL
Quoting Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
> Can you copy-paste (don't re-type) the mpiexec command (mpiexec -n
> 2 hostname) and the output in your email?
> Also try re-registering your username/password with mpiexec by
> following the steps below,
> # Remove any registered username/password using the "-remove" option
> of mpiexec (Type "mpiexec -remove" at the command prompt)
> # Register your username/password using the "-register" option of
> mpiexec (Type "mpiexec -register" and provide your username/password
> when prompted)
> # Validate that the registered username/password is valid/correct
> using the "-validate" option of mpiexec (Type "mpiexec -validate" at
> the command prompt)
> Please copy-paste (don't re-type) the commands and the outputs of
> the commands listed above. Let us know the results.
> (PS: It is important that we see the exact command line and the
> complete output for debugging your problem. So copy-paste the
> commands and the outputs in your email)
> Regards,
> jayesh
> From: Emil Sandoz-Rosado <ejs2166 at columbia.edu>
> To: 'Jayesh Krishna' <jayesh at mcs.anl.gov>
> Sent: Fri, 19 Nov 2010 10:24:30 -0600 (CST)
> Jayesh,
> That is the only line of output (it repeats itself once). I can't
> run any other programs.
> -Emil
> -----Original Message-----
> From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
> Sent: Wednesday, November 17, 2010 3:15 PM
> To: Emil Sandoz-Rosado
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] working mpi, now launch failure
> Hi,
> Is that the only output message from mpiexec (Just a line "launch
> failed: FAIL" ?)?
> Can you run a non-MPI program with mpiexec (mpiexec -n 2 hostname)?
> Can you run cpi.exe in the MPICH2 examples directory (mpiexec -n 2
> "c:\Program Files\MPICH2\examples\cpi.exe")?
> Regards,
> Jayesh
> Sent: Wed, 17 Nov 2010 14:11:28 -0600 (CST)
> Jayesh,
> This is what I put in and I get the same error.
> command:
>> mpiexec -n 2 C:\Users\Emil\Documents\LAAMPS\lmp_win_mpi.exe -in in.graphene
> error:
> launch failed: FAIL
> -Emil
>> Hi,
>> Try providing the complete path to the executable (lmp_win_mpi.exe)
>> and let us know if it works.
>> If you still have problems copy-paste the command and the error
>> message in your email.
>> Regards,
>> Jayesh
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Tue, 16 Nov 2010 16:15:16 -0600 (CST)
>> Subject: [mpich-discuss] working mpi, now launch failure
>> Jayesh,
>> I was able to get simulations running based on your suggestions. I shut the
>> machine down and then rebooted to run new simulations. Now when I attempt
>> to run mpiexec -n 2 lmp_win_mpi -in in.graphene, I get "launch failed: FAIL"
>> Smpd -status indicates smpd is running fine on the machine.
>> Any suggestions?
>> -Emil
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
