[mpich-discuss] mpi file operations do not work along nodes
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri May 28 11:49:58 CDT 2010
 Do you have a shared file system across the nodes ? Along with the sample program please provide us details on how you run your code (mpiexec command line, file system setup etc).
Jayesh
----- Original Message -----
Cc: tuncbah at gmail.com
Sent: Friday, May 28, 2010 9:43:34 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] mpi file operations do not work along nodes
 Can you send us a sample test program that fails ?
Jayesh
To: "mpich-discuss" <mpich-discuss at mcs.anl.gov>
Sent: Thursday, May 27, 2010 9:41:34 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] mpi file operations do not work along nodes
Hi all,
Our application works flawlessly when using message passing functions
from mpich2
but when we use mpi_file functions the output file is created but no
data is written to the output file.
Also no temporary file is created by mpich2.
This problem only occurs when we run the application along multiple nodes,
if we use single node multiple processes the application works fine.
I tried disabling anti virus(Mcafee enterprise 8.7.0i) scanning on the
application and all files under the mpich2 install folder
and windows firewall but nothing changed.
We use Windows XP sp3 with MPICH2 1.2.1p.
Any ideas ?
Thanks.
mpich-discuss mailing list
