[mpich-discuss] make fails with undefined reference VALGRIND_CHECK_MEM_IS_ADDRESSABLE
Wei-keng Liao
wkliao at ece.northwestern.edu
Tue May 18 13:40:39 CDT 2010
Hi, Dave,
I tried your approach by removing "meminit" from "--enable-g" and
deleting lines 25-35 of "src/include/mpiu_valgrind.h", but got the
following errors when ran a simple hello program.
I am using "--enable-g=dbg".
% mpiexec -l -n 4 hello
3: Fatal error in MPI_Init: Other MPI error, error stack:
3: MPIR_Init_thread(394).................: Initialization failed
3: MPID_Init(135)........................: channel initialization failed
3: MPIDI_CH3_Init(43)....................:
3: MPID_nem_init(202)....................:
3: MPIDI_CH3I_Seg_commit(366)............:
3: MPIU_SHMW_Hnd_deserialize(358)........:
3: MPIU_SHMW_Seg_open(897)...............:
3: MPIU_SHMW_Seg_create_attach_templ(671): open failed - No such file
or directory
rank 3 in job 9 aum0.cse.psu.edu_33436 caused collective abort of
all ranks
exit status of rank 3: return code 1
Wei-keng
On May 18, 2010, at 12:31 PM, Dave Goodell wrote:
> Yeah, that's the reason. I'll make some adjustments to the build
> system to handle this.
> -Dave
> On May 18, 2010, at 11:50 AM, Wei-keng Liao wrote:
>> It is valgrind-2.4.0
>> Wei-keng
>> On May 18, 2010, at 11:45 AM, Anthony Chan wrote:
>>> How about "valgrind --version" ?
>>> ----- "Wei-keng Liao" <wkliao at ece.northwestern.edu> wrote:
>>>> I checked valgrind.h on my system, but do not know how to tell the
>>>> valgrind version. Let me know if you have an idea.
>>>> Wei-keng
>>>> On May 18, 2010, at 10:51 AM, Dave Goodell wrote:
>>>>> What version of valgrind do you have installed?
>>>>> I suspect that your version of valgrind is older than anything
>>>>> that
>>>>> we've tested with and is slipping between the gap of "is
>>>>> valgrind.h
>>>>> available" and "does valgrind.h work". I can strengthen the
>>>>> configure test if I have an idea of what version of valgrind you
>>>> have.
>>>>> In the interim, the best workaround for you is probably to either
>>>>> remove "meminit" from your "--enable-g" arg, hack up the configure
>>>>> tests for valgrind so that they always fail, or delete lines 25-35
>>>>> of "src/include/mpiu_valgrind.h".
>>>>> -Dave
>>>>> On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
>>>>>> When running make of mpich2-1.2.1p1, I got an error complaining
>>>>>> undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please
>>>>>> see the attached standard outputs from configure and make.
>>>>>> The configure command and environment variables used are also
>>>>>> given
>>>>>> in out.configure file.
>>>>>> I am using GNU compilers, gcc and gfortran, to build MPICH2.
>>>>>> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
>>>>>> % rpm -q glibc
>>>>>> glibc-2.3.6-3
>>>>>> % uname -a
>>>>>> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006
>>>>>> i686
>>>>>> athlon i386 GNU/Linux
>>>>>> Wei-keng
>>>>>> <out.configure><out.make>
>>>>>> _______________________________________________
>>>>>> mpich-discuss mailing list
>>>>>> mpich-discuss at mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
