[mpich-discuss] make fails with undefined reference	VALGRIND_CHECK_MEM_IS_ADDRESSABLE
    Dave Goodell
    goodell at mcs.anl.gov
    Tue May 18 12:31:59 CDT 2010
Yeah, that's the reason.  I'll make some adjustments to the build system to handle this.
-Dave
On May 18, 2010, at 11:50 AM, Wei-keng Liao wrote:
> It is valgrind-2.4.0
> Wei-keng
> On May 18, 2010, at 11:45 AM, Anthony Chan wrote:
>> How about "valgrind --version" ?
>> ----- "Wei-keng Liao" <wkliao at ece.northwestern.edu> wrote:
>>> I checked valgrind.h on my system, but do not know how to tell the
>>> valgrind version. Let me know if you have an idea.
>>> Wei-keng
>>> On May 18, 2010, at 10:51 AM, Dave Goodell wrote:
>>>> What version of valgrind do you have installed?
>>>> I suspect that your version of valgrind is older than anything that
>>>> we've tested with and is slipping between the gap of "is valgrind.h
>>>> available" and "does valgrind.h work".  I can strengthen the
>>>> configure test if I have an idea of what version of valgrind you
>>> have.
>>>> In the interim, the best workaround for you is probably to either
>>>> remove "meminit" from your "--enable-g" arg, hack up the configure
>>>> tests for valgrind so that they always fail, or delete lines 25-35
>>>> of "src/include/mpiu_valgrind.h".
>>>> -Dave
>>>> On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
>>>>> When running make of mpich2-1.2.1p1, I got an error complaining
>>>>> undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please
>>>>> see the attached standard outputs from configure and make.
>>>>> The configure command and environment variables used are also given
>>>>> in out.configure file.
>>>>> I am using GNU compilers, gcc and gfortran, to build MPICH2.
>>>>> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
>>>>> % rpm -q glibc
>>>>> glibc-2.3.6-3
>>>>> % uname -a
>>>>> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006 i686
>>>>> athlon i386 GNU/Linux
>>>>> Wei-keng
>>>>> <out.configure><out.make>
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> mpich-discuss at mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
