[mpich-discuss] make fails with undefined reference	VALGRIND_CHECK_MEM_IS_ADDRESSABLE
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Tue May 18 11:50:05 CDT 2010
It is valgrind-2.4.0
Wei-keng
On May 18, 2010, at 11:45 AM, Anthony Chan wrote:
> How about "valgrind --version" ?
> ----- "Wei-keng Liao" <wkliao at ece.northwestern.edu> wrote:
>> I checked valgrind.h on my system, but do not know how to tell the
>> valgrind version. Let me know if you have an idea.
>> Wei-keng
>> On May 18, 2010, at 10:51 AM, Dave Goodell wrote:
>>> What version of valgrind do you have installed?
>>> I suspect that your version of valgrind is older than anything that
>>> we've tested with and is slipping between the gap of "is valgrind.h
>>> available" and "does valgrind.h work".  I can strengthen the
>>> configure test if I have an idea of what version of valgrind you
>> have.
>>> In the interim, the best workaround for you is probably to either
>>> remove "meminit" from your "--enable-g" arg, hack up the configure
>>> tests for valgrind so that they always fail, or delete lines 25-35
>>> of "src/include/mpiu_valgrind.h".
>>> -Dave
>>> On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
>>>> When running make of mpich2-1.2.1p1, I got an error complaining
>>>> undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please
>>>> see the attached standard outputs from configure and make.
>>>> The configure command and environment variables used are also given
>>>> in out.configure file.
>>>> I am using GNU compilers, gcc and gfortran, to build MPICH2.
>>>> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
>>>> % rpm -q glibc
>>>> glibc-2.3.6-3
>>>> % uname -a
>>>> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006 i686
>>>> athlon i386 GNU/Linux
>>>> Wei-keng
>>>> <out.configure><out.make>
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> mpich-discuss at mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
