[mpich-discuss] MPICH2 and LAPACK
Pavan Balaji
balaji at mcs.anl.gov
Mon May 10 17:51:41 CDT 2010
If I understand what you are doing correctly, you don't need to
recompile LAPACK -- you can continue using the single process LAPACK
functions within each MPI process. As you noted, you just compile your
application with mpif90 instead of gfortran; everything else stays the
same. For example, you can do:
% mpif90 foo.f -llapack -lblas
instead of
% gfortran foo.f -llapack -lblas
-- Pavan
On 05/10/2010 05:47 PM, Hélvio Vairinhos wrote:
> Hi,
> I am new to this forum, and this is my first post.
> I am developing a code in Fortran 90, and I use some basic MPI commands
> and LAPACK routines. I work in a Windows platform, but I use Cygwin for
> development. I use the LAPACK package that comes with the Cygwin
> installation, which works perfectly fine when I compile F90 codes with
> gfortran (the usual -llapack -lblas flags). But now I want to
> parallelized my code by adding some basic MPI commands. For this
> purpose, I installed MPICH2 from source, and use mpif90 to compile my
> parallel codes in Cygwin; it works perfectly fine! However, I don't know
> how to compile my codes when both MPI commands and LAPACK routine calls
> are present.
> So my questions are: How can I compile LAPACK routines (not ScaLAPACK)
> with mpif90? Is it possible to use the LAPACK routines that come with
> the Cygwin installation?
> Any help is appreciated. Thanks!
> -- Hélvio
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
