[mpich-discuss] MPICH2 and LAPACK
Hélvio Vairinhos helvio.vairinhos at googlemail.com
Mon May 10 21:46:49 CDT 2010
Thanks for the reply! I tried to compile my code using:
% mpif90 foo.f90 -llapack -lblas
but I always get the following message:
% /bin///ld: cannot find -llapack
% /bin///ld: cannot find -lblas
My test code is very simple:
   1. I initialize MPI,
   2. I construct two simple 5x5 matrices,
   3. I call the matrix multiplication routine (xGEMM),
   4. I print the result and RANK,
   5. I finalize MPI.
In principle this should return and print as many matrices as CPU's I
use to run the executable. However, mpif90 doesn't seem to allow the
-llapack or -lblas flags... So, since apparently I can't use the
libraries from the Cygwin installation, how should I proceed to be able
to compile LAPACK routines with mpif90?
Cheers,
-- Hélvio
On 10-05-2010 23:51, Pavan Balaji wrote:
> If I understand what you are doing correctly, you don't need to
> recompile LAPACK -- you can continue using the single process LAPACK
> functions within each MPI process. As you noted, you just compile your
> application with mpif90 instead of gfortran; everything else stays the
> same. For example, you can do:
> % mpif90 foo.f -llapack -lblas
> instead of
> % gfortran foo.f -llapack -lblas
>  -- Pavan
> On 05/10/2010 05:47 PM, Hélvio Vairinhos wrote:
>> Hi, I am new to this forum, and this is my first post.
>> I am developing a code in Fortran 90, and I use some basic MPI
>> commands and LAPACK routines. I work in a Windows platform, but I use
>> Cygwin for development. I use the LAPACK package that comes with the
>> Cygwin installation, which works perfectly fine when I compile F90
>> codes with gfortran (the usual -llapack -lblas flags). But now I want
>> to parallelized my code by adding some basic MPI commands. For this
>> purpose, I installed MPICH2 from source, and use mpif90 to compile my
>> parallel codes in Cygwin; it works perfectly fine! However, I don't
>> know how to compile my codes when both MPI commands and LAPACK
>> routine calls are present.
>> So my questions are: How can I compile LAPACK routines (not
>> ScaLAPACK) with mpif90? Is it possible to use the LAPACK routines
>> that come with the Cygwin installation?
>> Any help is appreciated. Thanks!
>> -- Hélvio
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
