[mpich-discuss] Windows/Linux MPICH2
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Mar 19 14:27:33 CDT 2010
 Good to know cpi is working.
# Did you recompile your target application after recompiling MPICH2 (with ch3:sock) ?
# Can you try running simple MPI programs (smallest possible) to narrow down on the problem ?
Jayesh
----- Original Message -----
From: "Matthew Chambers" <matthew.chambers at vanderbilt.edu>
Sent: Friday, March 19, 2010 2:13:59 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Windows/Linux MPICH2
Hi Jayesh,
Thanks! You solved the cpi problem. I suggest naming the Windows executable icpi instead of cpi. :)
I'm able to run icpi and cpi between Windows/Linux now, but my target application that runs fine with the Linux MPD ring hangs. I get the startup output "Process on <hostname> is starting" from the Windows machine but not the CentOS machine, so the Linux job is hanging in MPI_Init_thread, MPI_Buffer_attach, MPI_Comm_size, or MPI_Comm_rank.
It still behaves the same after starting smpd with SMPD_OPTION_NO_DYNAMIC_HOSTS set to 1.
-Matt
On 3/19/2010 1:52 PM, jayesh at mcs.anl.gov wrote:
 Couple of suggestions,
1) Turn SMPD dynamic host option off on the unix machines (Set the env variable "setenv SMPD_OPTION_NO_DYNAMIC_HOSTS 1" before starting the process manager, "smpd -s", on the unix machines.)
2) Do you have the same version of cpi installed on both unix and windows machines (The unix machines typically compile the non-interactive version, cpi.c and the windows installation have the interactive version, icpi.c) ?
Jayesh
mpich-discuss mailing list
