[mpich-discuss] Windows/Linux MPICH2
Matthew Chambers
matthew.chambers at vanderbilt.edu
Fri Mar 19 14:13:59 CDT 2010
Hi Jayesh,
Thanks! You solved the cpi problem. I suggest naming the Windows
executable icpi instead of cpi. :)
I'm able to run icpi and cpi between Windows/Linux now, but my target
application that runs fine with the Linux MPD ring hangs. I get the
startup output "Process on <hostname> is starting" from the Windows
machine but not the CentOS machine, so the Linux job is hanging in
MPI_Init_thread, MPI_Buffer_attach, MPI_Comm_size, or MPI_Comm_rank.
It still behaves the same after starting smpd with
SMPD_OPTION_NO_DYNAMIC_HOSTS set to 1.
-Matt
On 3/19/2010 1:52 PM, jayesh at mcs.anl.gov wrote:
> Hi,
> Couple of suggestions,
> 1) Turn SMPD dynamic host option off on the unix machines (Set the env variable "setenv SMPD_OPTION_NO_DYNAMIC_HOSTS 1" before starting the process manager, "smpd -s", on the unix machines.)
> 2) Do you have the same version of cpi installed on both unix and windows machines (The unix machines typically compile the non-interactive version, cpi.c and the windows installation have the interactive version, icpi.c) ?
> Regards,
> Jayesh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100319/8851b40e/attachment.htm>
