[mpich-discuss] Windows/Linux MPICH2
    Matthew Chambers
    matthew.chambers at vanderbilt.edu
    Fri Mar 19 15:00:25 CDT 2010
Eureka! I had forgotten to recompile my program after recompiling
MPICH2. Also discovered that it crashes with 1.3a1 but works fine with
1.2.1p1. I am now able to run my application between all three types of
nodes. However, I'm still annoyed by having to enter the password for
the Windows node. Is there a way to make that passwordless when
launching mpiexec from the CentOS box? The register_spn stuff would seem
to only apply to Windows.
Thanks!
-Matt
On 3/19/2010 2:27 PM, Jayesh Krishna wrote:
> Hi,
>   Good to know cpi is working.
> # Did you recompile your target application after recompiling MPICH2 (with ch3:sock) ?
> # Can you try running simple MPI programs (smallest possible) to narrow down on the problem ?
> Regards,
> Jayesh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100319/2543d4c6/attachment.htm>
