[mpich-discuss] mpich2-1.2.1p1 - cannot create regular	file`/index.htm': Permission denied
    Pavan Balaji
    balaji at mcs.anl.gov
    Thu Mar 11 15:43:34 CST 2010
Ah, I should have seen this earlier. My guess is that you are running
into the autotools ordering issue that we fixed in r6292
(http://trac.mcs.anl.gov/projects/mpich2/changeset/6292).
Can you try out the latest nightly snapshot to see if the problem still
exists?
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/trunk
 -- Pavan
On 03/11/2010 03:34 PM, Rajeev Thakur wrote:
> We build MPICH2 quite routinely following the exact steps in the README
> file, so something strange is happening in your specific case.
> Rajeev
>     *From:* mpich-discuss-bounces at mcs.anl.gov
>     [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Preeti
>     *Sent:* Thursday, March 11, 2010 1:26 PM
>     *To:* mpich-discuss at mcs.anl.gov
>     *Subject:* Re: [mpich-discuss] mpich2-1.2.1p1 - cannot create
>     Hi
>     Thanks for the replies, but I get following errors.
>     1. If I do only build in /tmp
>     cannot create regular file `/index.htm': Permission denied
>     2. if I do everything in /tmp, then the following error.
>      " Making all in mpl
>     /bin/sh: line 17: cd: mpl: No such file or directory
>     make[3]: *** [all-recursive] Error 1"
>     I have sent both log files earlier.
>     Yes, the /home/vss is network file system. I have no root access to
>     the system.
>     Is there any way out of this?
>     Please help.
>     Thanks
>     Preeti
>     On Thu, Mar 11, 2010 at 11:18 PM, Rajeev Thakur <thakur at mcs.anl.gov
>     <mailto:thakur at mcs.anl.gov>> wrote:
>         Just untar and build it again on a local disk. The install directory
>         (--prefix option to configure) can be on NFS.
>         Rajeev
>         > -----Original Message-----
>         > From: mpich-discuss-bounces at mcs.anl.gov
>         <mailto:mpich-discuss-bounces at mcs.anl.gov>
>         <mailto:mpich-discuss-bounces at mcs.anl.gov>] On Behalf Of
>         > chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>
>         > Sent: Thursday, March 11, 2010 11:48 AM
>         > To: mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>         > Subject: Re: [mpich-discuss] mpich2-1.2.1p1 - cannot create
>         > Is your /home/vss a local filesystem or some type
>         > network file system ?  If /home/vss is a network
>         > filesystem, the problem could be incorrect clock
>         > on the filesystem. If so, could you copy
>         > everything to a local filesystem like /tmp(assuming
>         > it is big enough) and try again ?
>         > ----- "Preeti" <preeti at csa.iisc.ernet.in
>         <mailto:preeti at csa.iisc.ernet.in>> wrote:
>         > > Hello
>         > > I have rebuilt everything without setting the flags also
>         > > /home/vss/preeti/bin/mpich2-1.2.1p1/configure
>         > > --prefix=/home/vss/preeti/bin/2-1.2.1build --enable-f90 2>&1
>         | tee
>         > > c.log
>         > > make 2>&1 | tee m.log
>         > > make install 2>&1 | tee mi.log
>         > > and this time I get the following error
>         > > /usr/bin/install -c -m 644 index.htm /index.htm
>         > > /usr/bin/install: cannot create regular file `/index.htm':
>         > Permission
>         > > denied
>         > > mkdir: cannot create directory `/www1': Permission denied
>         > > The log files are attached.
>         > > What am I missing?
>         > > Appreciate your help.
>         > > Thanks
>         > > Preeti
>         > > On Thu, Mar 11, 2010 at 4:37 PM, Preeti
>         <preeti at csa.iisc.ernet.in <mailto:preeti at csa.iisc.ernet.in>>
>         > > wrote:
>         > > > Hello
>         > > > I have rebuilt everything from scratch and did vpath build.
>         > > > I set the following
>         > > > export F90=gfortran
>         > > > export F77=gfortran
>         > > > export LD_LIBRARY_PATH=/usr/lib64:/lib:/usr/lib
>         > > > export LD_RUN_PATH=/usr/lib64:/lib:/usr/lib
>         > > > --prefix=/home/vss/preeti/bin/2-1.2.1p1 --enable-f90 2>&1
>         | tee
>         > > c.log
>         > > > Then I get the error
>         > > > Making all in mpl
>         > > > The files are attached.
>         > > > Please help.
>         > > > Thanks
>         > > > Preeti
>         > > > On Thu, Mar 11, 2010 at 1:53 AM, <chan at mcs.anl.gov
>         <mailto:chan at mcs.anl.gov>> wrote:
>         > > >> I don't think setting F77 and F90 causes the problem that
>         > > >> you are seeing.  The directories or subpackges that have
>         > > >> problems use a different build system than the majority of
>         > > >> mpich2 base, so it could be that there is bugs in the
>         > build system
>         > > >> in those subpackage.
>         > > >> Since you didn't do "make distclean" before you
>         reconfigure, so
>         > > >> the m.log(.old) do not tell me much. Can you rebuild
>         everything
>         > > >> from scratch ?  i.e. untar the mpich2 tarball in a different
>         > > location.
>         > > >> Instead of doing an inpath build (i.e. cd mpich2-1.2.1p1/ ;
>         > > >> ./configure....),
>         > > >> could you do a VPATH build as documented in the README
>         > (search for
>         > > the
>         > > >> word VPATH)?  Send us the configure and make outputs again
>         > > >> (be sure to add 2>&1 in creating the output files).
>         > > >> A.Chan
>         > > >> > Hello
>         > > >> > Thank you for the quick response.
>         > > >> > I forgot to mention that I had set two flags earlier.
>         > > >> > export F90=gfortran
>         > > >> > export F77=gfortran
>         > > >> > The earlier problem is gone when I compiled without setting
>         > > these. I
>         > > >> > am
>         > > >> > attaching all log files, the earlier ones and the new ones.
>         > > >> > Now I am facing another error which is from "make
>         install 2>& |
>         > > tee
>         > > >> > mi.log"
>         > > Permission
>         > > >> > denied
>         > > >> > Probably some variable is not set. I tried setting
>         docdir too.
>         > > >> > mi.log is also attached.
>         > > >> > Please help.
>         > > >> > Thanks
>         > > >> > Preeti
>         > > >> > On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov
>         > > >> > > It is unclear what went wrong based on what you've
>         > provided so
>         > > far.
>         > > >> > > Can you send us the configure and make outputs as
>         stated in
>         > > the
>         > > >> > > README (be sure to include the stderr in the output
>         file) ?
>         > > >> > > > Hello
>         > > >> > > > I am trying to install mpich2-1.2.1p1 on a 64-bit Linux
>         > > system.
>         > > >> > > > Configuration was successful.
>         > > >> > > > ./configure --prefix=$HOME/local/mpich2-1.2.1
>         > --enable-f90 |
>         > > tee
>         > > >> > > > c.log
>         > > >> > > BTW, you didn't include stderr in c.log.  Depends on
>         > the shell
>         > > you
>         > > >> > > use, you need to either add "&" or "2>&1".  See
>         README for
>         > > >> > details..
>         > > >> > > A.Chan
>         > > >> > > _______________________________________________
>         > > >> > > mpich-discuss mailing list
>         > > >> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>         > > >> > > This message has been scanned for viruses and
>         > > >> > > dangerous content by MailScanner, and is
>         > > >> > > believed to be clean.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
