[mpich-discuss] mpd problems
    Dave Goodell
    goodell at mcs.anl.gov
    Thu Mar 11 11:42:57 CST 2010
Have you tried the mpd troubleshooting steps described in Appendix A
of the MPICH2 Installer's Guide (mpdcheck)?  http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
What version of MPICH2 are you using?
-Dave
On Mar 11, 2010, at 10:36 AM, Jacob Harvey wrote:
> Dear MPI users,
> I am having problems getting mpd's started on my nodes. The problem
> actually only seems to occur when I try and start an mpd ring from the
> head node. For instance when I am on the head node and I type:
> mpdboot -n 3  -r ssh
> where my mpd.hosts file reads:
> node005
> node006
> I get the following error:
> mpdboot_head (handle_mpd_output 415): failed to connect to mpd on
> node005
> However, if I run the same command on node005:
> mpdboot -n 3 -r ssh
> head
> node006
> everything works fine, and I can run mpdtrace and get:
> node005
> head
> node006
> It kinda seems like this is an ssh problems, but I'm able to ssh to
> node005 from the head node without being asked for a password. So I'm
> a little lost as to what the problem here is. Any help would be
> greatly appreciated!
> Jacob
> Jacob Harvey
> Graduate Student
> University of Massachusetts Amherst
> j.harv8 at gmail.com
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
