[mpich-discuss] mpich2-1.2.1p1 - cannot create regular file `/index.htm': Permission denied
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Thu Mar 11 11:47:38 CST 2010
Is your /home/vss a local filesystem or some type
network file system ?  If /home/vss is a network
filesystem, the problem could be incorrect clock
on the filesystem. If so, could you copy
everything to a local filesystem like /tmp(assuming
it is big enough) and try again ?
----- "Preeti" <preeti at csa.iisc.ernet.in> wrote:
> Hello
> I have rebuilt everything without setting the flags also
> /home/vss/preeti/bin/mpich2-1.2.1p1/configure
> --prefix=/home/vss/preeti/bin/2-1.2.1build --enable-f90 2>&1 | tee
> c.log
> make 2>&1 | tee m.log
> make install 2>&1 | tee mi.log
> and this time I get the following error
> /usr/bin/install -c -m 644 index.htm /index.htm
> /usr/bin/install: cannot create regular file `/index.htm': Permission
> denied
> mkdir: cannot create directory `/www1': Permission denied
> The log files are attached.
> What am I missing?
> Appreciate your help.
> Thanks
> Preeti
> On Thu, Mar 11, 2010 at 4:37 PM, Preeti <preeti at csa.iisc.ernet.in>
> wrote:
> > Hello
> > I have rebuilt everything from scratch and did vpath build.
> > I set the following
> > export F90=gfortran
> > export F77=gfortran
> > export LD_LIBRARY_PATH=/usr/lib64:/lib:/usr/lib
> > export LD_RUN_PATH=/usr/lib64:/lib:/usr/lib
> > --prefix=/home/vss/preeti/bin/2-1.2.1p1 --enable-f90 2>&1 | tee
> c.log
> > Then I get the error
> > Making all in mpl
> > /bin/sh: line 17: cd: mpl: No such file or directory
> > make[3]: *** [all-recursive] Error 1
> > The files are attached.
> > Please help.
> > Thanks
> > Preeti
> > On Thu, Mar 11, 2010 at 1:53 AM, <chan at mcs.anl.gov> wrote:
> >> I don't think setting F77 and F90 causes the problem that
> >> you are seeing.  The directories or subpackges that have
> >> problems use a different build system than the majority of
> >> mpich2 base, so it could be that there is bugs in the build system
> >> in those subpackage.
> >> Since you didn't do "make distclean" before you reconfigure, so
> >> the m.log(.old) do not tell me much. Can you rebuild everything
> >> from scratch ?  i.e. untar the mpich2 tarball in a different
> location.
> >> Instead of doing an inpath build (i.e. cd mpich2-1.2.1p1/ ;
> >> ./configure....),
> >> could you do a VPATH build as documented in the README (search for
> the
> >> word VPATH)?  Send us the configure and make outputs again
> >> (be sure to add 2>&1 in creating the output files).
> >> A.Chan
> >> > Hello
> >> > Thank you for the quick response.
> >> > I forgot to mention that I had set two flags earlier.
> >> > export F90=gfortran
> >> > export F77=gfortran
> >> > The earlier problem is gone when I compiled without setting
> these. I
> >> > am
> >> > attaching all log files, the earlier ones and the new ones.
> >> > Now I am facing another error which is from "make install 2>& |
> tee
> >> > mi.log"
> Permission
> >> > denied
> >> > Probably some variable is not set. I tried setting docdir too.
> >> > mi.log is also attached.
> >> > Please help.
> >> > Thanks
> >> > Preeti
> >> > On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov> wrote:
> >> > > It is unclear what went wrong based on what you've provided so
> far.
> >> > > Can you send us the configure and make outputs as stated in
> the
> >> > > README (be sure to include the stderr in the output file) ?
> >> > > > Hello
> >> > > > I am trying to install mpich2-1.2.1p1 on a 64-bit Linux
> system.
> >> > > > Configuration was successful.
> >> > > > ./configure --prefix=$HOME/local/mpich2-1.2.1 --enable-f90 |
> tee
> >> > > > c.log
> >> > > BTW, you didn't include stderr in c.log.  Depends on the shell
> you
> >> > > use, you need to either add "&" or "2>&1".  See README for
> >> > details..
> >> > > A.Chan
> >> > > _______________________________________________
> >> > > mpich-discuss mailing list
> >> > > mpich-discuss at mcs.anl.gov
> >> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> >> > > This message has been scanned for viruses and
> >> > > dangerous content by MailScanner, and is
> >> > > believed to be clean.
