[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
    Timothy LeBlanc
    timothy.leblanc at gmail.com
    Thu Jun  3 14:31:19 CDT 2010
Hi Dave
When I run the command
/configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install 2>&1 |
tee c.txt
The display only shows about 20 lines before failing they are:
Configuring MPICH2 version 1.2.1p1 with  'CFLAGS=-Wa,--divide'
'--prefix=/usr/local/bin/mpich2-install'
Running on system: SunOS mars 5.10 Generic_141445-09 i86pc i386 i86pc
Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3 with
/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/setup_pm
checking for gcc... gcc
checking for C compiler default output file name...
configure: error: in `/work/mpich2/mpich2-1.2.1p1':
configure: error: C compiler cannot create executables
See `config.log' for more details.
Do you still want me to run make and send you the m.txt file?
Tim
On Thu, Jun 3, 2010 at 2:40 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> On Jun 3, 2010 , at 1:29 PM CDT, Timothy LeBlanc wrote:
> > --divide does not seem to be an acceptable parameter . When I type in
> configure --help it is not listed and it fails when I try using it.
> > So I followed up with running:
> > ./configure CFLAGS=-Wa, --prefix=/usr/local/bin/mpich2-install 2>&1 | tee
> c.txt
> This is the not the format you should use.  The whole "-Wa,--divide"
> matters.  So the command should look like the first one you listed:
>  ./configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install
> 2>&1 | tee c.txt
> > And this fails in the same way as I explained. Seems to configure ok but
> then the make fails.
> Please send us the m.txt from the make command when using the above
> configuration:
>  make V=1 2>&1 | tee m.txt
> I'm surprised that this didn't work for you and I'd like to see what's
> really going on here.
> -Dave
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
The information contained in this E-mail message is privileged,
confidential, and may be protected from disclosure; please be aware that any
other use, printing, copying, disclosure or dissemination
of this communication may be subject to legal restriction or sanction. If
you think that you have received this E-mail message in error, please reply
to the sender and delete it from your computer. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100603/db138ffe/attachment.htm>
