[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
    Dave Goodell
    goodell at mcs.anl.gov
    Thu Jun  3 14:33:09 CDT 2010
No.  In that case, please send the config.log instead.
-Dave
On Jun 3, 2010 , at 2:31 PM CDT, Timothy LeBlanc wrote:
> Hi Dave
> When I run the command
> /configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
> The display only shows about 20 lines before failing they are:
> Configuring MPICH2 version 1.2.1p1 with  'CFLAGS=-Wa,--divide' '--prefix=/usr/local/bin/mpich2-install'
> Running on system: SunOS mars 5.10 Generic_141445-09 i86pc i386 i86pc
> Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3 with
> Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
> sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
> sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
> sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
> sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/setup_pm
> checking for gcc... gcc
> checking for C compiler default output file name...
> configure: error: in `/work/mpich2/mpich2-1.2.1p1':
> configure: error: C compiler cannot create executables
> See `config.log' for more details.
> Do you still want me to run make and send you the m.txt file?
> Tim
> On Thu, Jun 3, 2010 at 2:40 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> On Jun 3, 2010 , at 1:29 PM CDT, Timothy LeBlanc wrote:
> > --divide does not seem to be an acceptable parameter . When I type in configure --help it is not listed and it fails when I try using it.
> > So I followed up with running:
> > ./configure CFLAGS=-Wa, --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
> This is the not the format you should use.  The whole "-Wa,--divide" matters.  So the command should look like the first one you listed:
>  ./configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
> > And this fails in the same way as I explained. Seems to configure ok but then the make fails.
> Please send us the m.txt from the make command when using the above configuration:
>  make V=1 2>&1 | tee m.txt
> I'm surprised that this didn't work for you and I'd like to see what's really going on here.
> -Dave
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
> The information contained in this E-mail message is privileged, confidential, and may be protected from disclosure; please be aware that any other use, printing, copying, disclosure or dissemination
> of this communication may be subject to legal restriction or sanction. If you think that you have received this E-mail message in error, please reply to the sender and delete it from your computer. Thank you.
